Ac bracket support
Old Jul 11, 2011 | 05:55 PM
Ricky 91 vette's Avatar
Ricky 91 vette
Default Ac bracket support
I think I'm missing the support bracket from the ac compressor to the exasust intake, I only heard about it , I haven't seen it, and i dont know where it supose to be mounted, could any one take a picture and post it here or send it to my e mail pls? Its :
Arkan17may@yahoo.com
Thanks a lot Ricky
By the way it's for 1991 corvette with l98
Old Jul 11, 2011 | 11:28 PM
Ricky 91 vette
Any one pls would bother And take some pics for me pls
Old Jul 12, 2011 | 12:46 AM
Ricky 91 vette
Bump
Old Jul 12, 2011 | 04:21 AM
vetteoz's Avatar
vetteoz
Old Jul 12, 2011 | 04:23 AM
vetteoz's Avatar
vetteoz
Have you got the bottom support bracket that goes to a stud on fuel pump block off plate ? (yellow # 6)
and the one that goes to bolt on water pump? (red # 5 )
Old Jul 12, 2011 | 06:09 AM
Ricky 91 vette
vetteoz
thanks a milion for the pics, the upper bracket ( on the newspaper) i have it at home! the mechanic who installed the hooker long tubes headers gave it to me with the original exasust manifolds last year, i remembered asking him about it and why its not on the car and he said that it belongs to the manifolds and its not important!! now i had to replace my ac bracket last week after it broke down into 3 pieces!!! when i heard that im supose to have a suporting bracket between the compressor and the exasust manifold, i was suspecting it, but i couldnt figure out where it mounts!! it looks from the pics that it mounts on the front bolt on #4 tube, right?
Old Jul 12, 2011 | 06:13 AM
Ricky 91 vette
and yes i have the bottom bracket already in its place, but i dont have the one that bolts on the water pump!!! by missing 2 supporting brackets, no wonder my ac bracket gave up and broke down!! im sure GM is smarter than that freaken mechanic!!
Old Jul 12, 2011 | 06:16 AM
Ricky 91 vette
vetteoz
do u have by chance a pic for the bracket that bolts to the water pump that im missing to know where it bolts exactly?
thanks again for the help
ricky
Old Jul 13, 2011 | 01:30 AM
vetteoz's Avatar
vetteoz
Originally Posted by Ricky 91 vette
he said that it belongs to the manifolds.. it looks from the pics that it mounts on the front bolt on #4 tube, right?
You need to make a tube spacer same length as the tube in original manifolds and use the original bolt to position bracket correctly.
Old Jul 13, 2011 | 01:34 AM
vetteoz's Avatar
vetteoz
Old Jul 13, 2011 | 01:48 AM
Ricky 91 vette
Thanks I will measure the original one I make it smiler, luckley I have the original bolts too!
Old Jul 13, 2011 | 02:12 AM
Ricky 91 vette
Thanks again vetteoz
Old Jul 13, 2011 | 02:53 AM
gerardvg's Avatar
gerardvg
Default a/c bracket support
Oh no !!!! i dont have the lower brace on my vette
best do it now before this a/c bracket gets damaged
Thanks Vetteoz for the great pics
Old Jul 13, 2011 | 03:31 AM
Ricky 91 vette
I don't know how to load pics here into the forum, otherwise I would show how mine broke into 3 pieces!! I got it for about $ 60 from a member but trust me man, it's not fun to put that thing in!!!
Old Jul 13, 2011 | 04:12 AM
gerardvg's Avatar
gerardvg
Default Re a/c bracket
Hi
Make sure you hold the bracket in place before adding a/c.
Some water pumps do not allow the a/c bracket to seat properly, check for gaps at the head water pump and block mounting points.
Especially pay attention to the heater return pipe sticking out of the water pump , i ended up putting washers between the block and a/c bracket to make sure the a/c bracket was not under stress from misaligned mounting holes.
That is how my first a/c bracket broke when i tightened the bolts after replacing the water pump .... it was not machined properly at the bolt mounting. I know now to check the fit before i torque the bolts Please check this when fitting your replacement a/c bracket
Old Jul 14, 2011 | 03:57 AM
Ricky 91 vette
Hi
I'm not sure... I already replaced the bracket with no troubles, actually I can't remember it had to do with anything with the water pump, exept for the heater hose, it fit perfectly there
Old Jul 14, 2011 | 05:34 AM
mistaben's Avatar
mistaben
make an account at photobucket . com
load your pics.
select your pics that you want to upload and use the IMG tag line. litterally it will give you 4 different loading options, copy the IMG tagline into your clipboard, then you go over to the forum you want to paste in and hit ctrl+v to paste (or right click and select paste). and there you go.
To Ac bracket support
Old Jul 15, 2011 | 05:19 AM
Ricky 91 vette
load your pics.
Thanks, I tried it and it didn't work because the image needs to be resized and I don't know how, I'll call my computer expert brother tomorrow to asklol him to do that! lol
Old Jul 21, 2011 | 09:54 PM
Ricky 91 vette
lets give it another shot here
Old Jul 21, 2011 | 09:56 PM
Ricky 91 vette
i made it!!
