93 crank sensor !!!!!!!!!!!!?>??
Old Jul 11, 2011 | 11:06 PM
barney10mm's Avatar
barney10mm
Default 93 crank sensor !!!!!!!!!!!!?>??
do i have ? if so where ?
Old Jul 12, 2011 | 03:45 AM
toptechx6's Avatar
toptechx6
93 has no crank position sensor, 96 was the first year Corvette to use one.
Old Jul 12, 2011 | 08:53 PM
barney10mm's Avatar
barney10mm
thx ,i m not getting a signal to my injectors , i replaced plugs icm ecm coil dist . cap......wth ?im out of $$$$$$$$$$$$
Old Jul 12, 2011 | 09:29 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Old Jul 13, 2011 | 04:01 AM
toptechx6's Avatar
toptechx6
Cam and crank position information is sent to the ECM from the optical sensor in the distributor. Here is a link to help diagnose problems with the Opti.
http://www.camaroz28.com/forums/showthread.php?t=601565
Old Jul 13, 2011 | 06:22 AM
TWISTERUP's Avatar
TWISTERUP
If you have spark to the plugs--I'd disconnect all the injector connectors then connect a noid light and see if you have pulse to the injectors-- if you do have pulse (noid light blinks) then ohm each injector.They should all be fairly equal around 16 ohms-- you may have 2-3 bad injectors shutting down the drivers in the ECM. If you DON'T have pulse when checking with the noid light-you may have a VATS issue-- JMO
Old Jul 13, 2011 | 09:02 AM
barney10mm's Avatar
barney10mm
ign control mod . is gettin very hot and that s the prob . but why ?? its new
Old Jul 13, 2011 | 10:42 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
OK, take a deep breath.
When you replaced the ICM did you put thermal paste between the ICM and the heatsink?
No - you fried your new ICM - make sure you put thermal paste on the new one.
Yes - then its time to look at wiring.
As things heat up they expand, the connectors that plug into the ICM and the ECM harness are subjected to lots of heat. You may have conductors that are not making 100% contact - check them.
There is also a procedure to check voltages from the ICM and trigger from the opti.
Its in the FSM, and I've seen a couple of posts talking about it.
Old Jul 13, 2011 | 06:50 PM
barney10mm's Avatar
barney10mm
ok thx . what does the heat sink do ?
Old Jul 13, 2011 | 07:04 PM
TWISTERUP's Avatar
TWISTERUP
Short story is it helps transfer heat away from the ICM so it stays cooler.
Old Jul 13, 2011 | 09:28 PM
barney10mm's Avatar
barney10mm
ok , thats weird . lol .... but still dosent work .
Old Jul 13, 2011 | 11:10 PM
surfer93's Avatar
surfer93
Ok if you did not put the dialectic grease on the ICM and it should have come with the new one, then you fried it and it will not help to put it on afterwards.
I say this all the time on this forum and no one listens - 'Diagnose first and save yourself money and frustration'.
Search the forum, 99% of all problems have already been answered.
Old Jul 14, 2011 | 12:15 PM
MK 82's Avatar
MK 82
Dielectric grease and heat sink paste are two different animals for two different purposes.
To 93 crank sensor !!!!!!!!!!!!?>??
