Runner Bolt Question
Old Jul 12, 2011 | 03:01 PM
Vette'76's Avatar
Vette'76
8th Gear
Default Injector Change Runner Bolts
90' Vert/Runner passenger side bolts runner to intake 5 bolts 2 longest ones in bottom holes, now the question, 2 of the 3 bolts are the same size one is a little longer than the other what hole does the longer one go in? Thanks
Old Jul 12, 2011 | 07:42 PM
Vette'76's Avatar
Vette'76
8th Gear
Any Ideas?
Old Jul 12, 2011 | 08:19 PM
stoydido's Avatar
stoydido
there are 5 on btom runner, 4 on top. longer ones go inside, btm. there is also one on front of btm runner, opposite side near rail, for total of 6. if I remamber, that one is longer, had a slight shoulder on it.
if you get them mixed, you should notice. if too long in blind holes, they won't seat.
Old Jul 12, 2011 | 08:32 PM
Vette'76's Avatar
Vette'76
8th Gear
Runner side 2 long ones bottom of runner ok, one on rail side ok, 3 for top of bottom runner 1? has a shoulder on it,where does it go?
Old Jul 12, 2011 | 08:40 PM
stoydido's Avatar
stoydido
I'm getting lost. you're talking bottom bolts only, correct? I said that the longer, by .2" or so, with the shoulder, I THINK was the inside bolt that was accessible from the driver's side.
the longer two go to inside bottom holes, one clear to se, the other on left side hidden.
we commnicating? maybe I better go count them again.
Old Jul 12, 2011 | 08:44 PM
stoydido's Avatar
stoydido
I am wrong. the longer bolts went to the "almost blind" holes, that are almost impossible to reach without a swivel universal and a 1/4 drive extension. have to be assembled in the runner holes before seating runner.
Old Jul 12, 2011 | 09:04 PM
Vette'76's Avatar
Vette'76
8th Gear
Im talking about the intake bottom of runner, there are a total of 6, one of those comes from the rail side, the two long ones on the hard to get to places on bottom, three bolts left for the top of the lower runner, they are short but one has a small shoulder on it that is the one in question.
Old Jul 12, 2011 | 09:11 PM
stoydido's Avatar
stoydido
I thought I said or meant to that it is I THINK the one from opposite side. Try to fit it there first, and it will be obvious if it is too long. try a short one, same thing. are we sure it came from btm runner? I remember one was too long, and switched, not sure which ones.
Old Jul 12, 2011 | 09:25 PM
Vette'76's Avatar
Vette'76
8th Gear
Those "Lower runner passenger side" bolts are the only bolts in the process that got scrambled. Thanks
Old Jul 12, 2011 | 09:34 PM
stoydido's Avatar
stoydido
yep, same here. in the overall scheme of things, if they are long, you'll know it, most likely. if a little short, you only need a couple of threads to secure it at such low torque. a common sheet metal screw has 1.5 threads engagement.
with all the activity here with guys changing injectors I figured you'd have a dozen or so responding, didn't you?
jc
Old Jul 13, 2011 | 12:00 AM
Vette'76's Avatar
Vette'76
8th Gear
ttt
Old Jul 13, 2011 | 12:52 AM
90vett's Avatar
90vett
Ill check mine to see if I see where it goes, but may be a while, like maybe Friday. Some body else might know without looking.
Old Jul 14, 2011 | 07:03 AM
Vette'76's Avatar
Vette'76
8th Gear
ttt
To Runner Bolt Question
