Help: '88 no power under load
Old Jul 20, 2011 | 04:33 PM
nato4015's Avatar
nato4015
Default Help: '88 no power under load
Your assistance is greatly appreciated.
No power under load from small throttle through to WOT. Stumbling, no "power".
My 1988 has been modified with the American Racing Header's (no smog, no egr) I've just put in a brand new adjustable fuel pressuer regulator and it's spot on 48 lbs. Timing set at 6 degrees btdc. Brand new TPS. Idles and Rev's just fine sitting still, only under load does it stumble and falter. All new ignition and cooling too.
Any idea's are appreciated. I don't really want to throw more money at it guessing.
Old Jul 20, 2011 | 04:57 PM
stoydido's Avatar
stoydido
modifying the "smog" equipment and eliminating egr are wrong headed. I've read many threads where engines were not "right" after monkeying with it.
possibility that exhaust system is restrictive. retarded timing causes a soft throttle. would you bet that it is actually 6*? if not set properly, it can be retarded but appear to be advanced.
but...sounds like insufficient fuel. no missing, just not performing.
someone will have the same experience and can help more than I.
Old Jul 22, 2011 | 11:40 AM
Corvette40's Avatar
Corvette40
I also have an 88 that had the same problem. Turned out my pre cats came apart and clogged the main cat. Since you have headers you probably don't have pre cats, but what about the main cat?
Old Jul 23, 2011 | 03:57 PM
nato4015's Avatar
nato4015
Brand new cats came in the X-pipe from American Racing Headers. High flow. Maybe 20 miles on them. Thanks for your comments though. Hopefully I get it narrowed down.
Natilla the Hun!
Old Jul 23, 2011 | 09:42 PM
TPI BOY's Avatar
TPI BOY
when was the last time you changed the fuel filter
Old Jul 24, 2011 | 11:40 PM
nato4015's Avatar
nato4015
About twenty miles ago. Thanks for chiming in. I wish that were it. The 8 dollar part from wal mart while i was picking up oil for it and my truck.
Natilla
Old Jul 25, 2011 | 12:53 AM
nato4015's Avatar
nato4015
Yep, its a nice exhaust system. Non stepped cats in x 200 cell substrate i believe,..off hand.
Old Jul 25, 2011 | 02:09 AM
Cliff Harris's Avatar
Cliff Harris
You said all new ignition, but my feeling is that you need to check the resistance of your plug wires.
I had a bad wire when I had this symptom.
Did you check for codes?
Old Jul 25, 2011 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I've just put in a brand new adjustable fuel pressuer regulator and it's spot on 48 lbs. .
I assume that's at idle, but what does the pressure do under load ? Will your gauge reach the windshield so you can monitor it under real load ?
Old Jul 25, 2011 | 10:38 AM
nato4015's Avatar
nato4015
I did the tape the tape the guage to the windshield. Under load it seemed inconclusive to me. It was up and down?? I was hoping it would seriously go one way or the other. With the vacuum line plugged in, it is exactly 10 lbs lower.
Old Jul 25, 2011 | 12:26 PM
TPI BOY's Avatar
TPI BOY
With the vacuum line plugged in, it should go up
at WOT. compaired to idle. with line pluged in.
Old Jul 25, 2011 | 12:43 PM
AGENT 86's Avatar
AGENT 86
All new ignition
Is the coils ground strap attached to cap with one of the four coil bolts ?
Old Jul 25, 2011 | 05:27 PM
nato4015's Avatar
nato4015
Default Corrected but not Corrected
Thank so much for everyone who chimed in.
Agent 86, nice, you were getting close.
I FIGURED IT OUT! Yeah.
Here's what it was.
I bought one of those new "fancy" ""corrected"" distributor caps from accell for the clean look and tidy wiring. It didn't like it. Today, I put back the old one for testing, after a new TPS and fuel pump still no dice. Changed out the distributor cap to the old one,...runs like a champ!!
I was glad it wasn't the chip. No codes. PCM for less had everything I did to it and it was fine, runs real strong now with an American Racing Header no smog with Cats in the xpipe. into 2.5 stock type no drones for a turbo sound. It does not sound like a mustang gt thats for sure.
Thanks again guys. I really appreciate your taking the time to help me with your suggestions. I was just under the knife, and start chemo this coming Monday, so I wanted to finally sort it before feeling like crap . (Having goofed with it all spring (Header install on a 4+3 WITH KC4 was a challenge, but I was up for it).
Have a wonderful Day!!!
Natilla the Hun
To Help: '88 no power under load
