Planning LT1 Perf. Upgrade
Old Aug 3, 2011 | 11:57 AM
  #41
CAJUN C4's Avatar
CAJUN C4
I just found out that the stock lenghth pushrods are fine with just a cam upgrade. They are hardend chrome moly and will work with guide plates? Is this correct?
Dennis
Old Aug 3, 2011 | 03:48 PM
  #42
STL94LT1's Avatar
STL94LT1
Dennis
Changing heads and a thinner head gasket can throw off your valvetrain geometry. Just make sure you check your pushrod length. Yes if the correct length, the Chromemoly pushrods will work with guide plates.
Old Aug 4, 2011 | 07:56 AM
  #43
CAJUN C4's Avatar
CAJUN C4
Your right..I will check for correct length.
Old Aug 4, 2011 | 03:47 PM
  #44
ScaryFast's Avatar
ScaryFast
I say don't bother with the bigger TB, stay stock. Smaller means less flow but more air velocity. I have a more aggressive build than you, but back to back dyno showed an INCREASE in power changing from my 52mm to a stock 48 mm LT1 TB.
Of course either way you need a tune, the car leaned out with the smaller TB which wouldn't be safe.
TB's are like tires, everyone tells you to get the biggest that will fit on your car but that's not always true.
Old Aug 4, 2011 | 07:15 PM
  #45
CAJUN C4's Avatar
CAJUN C4
That's why I chose the Heads I did. A tad smaller port but higher velocity with great flow.
Old Aug 4, 2011 | 09:30 PM
  #46
HlhnEast's Avatar
HlhnEast
Yer not done yet???
Old Aug 5, 2011 | 09:52 AM
  #47
CAJUN C4's Avatar
CAJUN C4
Originally Posted by HlhnEast
Yer not done yet???
LOL...Remember Steve.."Success is a Journey, NOT a destination".
I'm almost finishing gathering parts.And a HUGE thanx to all you guys for your help and advice.
Old Aug 5, 2011 | 10:38 AM
  #48
LT4BUD's Avatar
LT4BUD
Right on......the throttle body size has little if anything to do with port velocity.....
Old Aug 10, 2011 | 07:36 AM
  #49
CAJUN C4's Avatar
CAJUN C4
Default A Step Closer
Purchased my OBX Headers Yesterday. $475.00 + $45.00 UPS
One step Closer.
Old Aug 10, 2011 | 03:48 PM
  #50
CAJUN C4's Avatar
CAJUN C4
Fair price to weld up to Headers?
Old Aug 10, 2011 | 04:29 PM
  #51
HlhnEast's Avatar
HlhnEast
Last guy I used was $50/hr but that was a few years ago. I assume your talking about welding up the A.I.R. tubing? It shouldnt take more than an hour or two.
Keep the information coming, Dennis!
Old Aug 10, 2011 | 05:20 PM
  #52
STL94LT1's Avatar
STL94LT1
I paid ~$120 to have my headers connected to the cat-back. They built 3"-2.5" adapters, narrowed/shortened the cat-back tubes, and installed an extra o2 bung for this price.
