broken spark
Old Jul 23, 2011 | 05:58 PM
gunna's Avatar
gunna
Navigator
Default broken spark
broke spark plug off anyone got a fix
Old Jul 23, 2011 | 06:10 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
How are we supposed to help?
Year of car?
what part of the spark plug broke off?
Can you get the plug out?
threads messed up?
Every one of these has an answer and a different fix.
Broke sparkplug doesn't help
Old Jul 23, 2011 | 06:18 PM
gunna's Avatar
gunna
Navigator
Year of car?
threads messed up?
porsalen and nut part broke off and electrod stayed in side
Old Jul 23, 2011 | 08:10 PM
pcolt94's Avatar
pcolt94
Sounds like the threaded part is still in without the nut to turn it. The threads might not be as tight as you think it might be. As a starting point I would try to get a hold of that piece somehow and just try to turn it. Don't know if it would be possible to drill a small hole or two in it to try to get a better grip in it.
Old Jul 23, 2011 | 08:46 PM
Pwnage1337's Avatar
Pwnage1337
Vice grips.
Old Jul 23, 2011 | 09:15 PM
87 vette 81 big girl's Avatar
You Need a Square Easy Out broken bolt removal tool.
I have never had that happen on any Corvette I worked on or my own.
But happens to me every Fall & Winter when I have to Tune up Snow Plow trucks for the coming winter season here in Illinois.
Calcium Chloride will corrode the main frame rails into nothing on those trucks within 2 or 3 yeas.
Eats holes right through the cast Iron exhaust manifolds.
2" inch holes.
Take the correct sized square drive bodied easy out tool & place it into the remainder of the spark plug.
Tap it in with a Ball Peen Hammer.
With a good Cresent Wrench & PB blaster applied,
Remove the spark plug shell threads counterclockwise.
It will come out for You.
I have had to do it dozens of times.
Its just a PIA.
Nothing else works correctly besides one of those special tapered square drive bodied easy out tools.
Have a set in my toolbox at work.
Brian
Old Jul 23, 2011 | 10:28 PM
gunna's Avatar
gunna
Navigator
2" inch holes.
Its just a PIA.
Brian
thanks will let u know the out come
Old Jul 23, 2011 | 10:41 PM
Check with the Local Harbor Freight Tools supply outlet in your area.
I think I have seen them there too for sale.
The spiral kind of easy out removal tools don't work too well on those broken off spark plug threaded shells remaining in the cylinder head.
The Tapered square drive bodied easy out removal tool "digs in deep" & the shock of the ball peen hammer works the rust loose also.
I have a favorite Blue Point ball Peen Hammer on a wooden hickory handle.
18 ounce steel head.
Something similar will work great for you too.
You need to "SMACK" that square drive tool sharply in to use it correctly.
Or otherwise it will slip off when turned with a Cresent wrench.
Hit it dead on with the Ball Pean Hammer so you don't smack your Free Hand holding the tool!
Brian
Old Jul 24, 2011 | 12:36 PM
gunna's Avatar
gunna
Navigator
Brian
thanks got it out and running great
Old Jul 24, 2011 | 12:53 PM
You are welcome.
Glad I could help You out.
1st time that happened to me about 10 years ago........broken off spark plug threaded in shell in the cylinder head still stuck & intact I panicked too.
An old timer mechanic showed me the same trick I told you about.
BR
Old Jul 24, 2011 | 01:52 PM
pcolt94's Avatar
pcolt94
2" inch holes.
Its just a PIA.
Brian
I will have to remember this and hope I won't have to use it.
I actually thought about an easy out but since I did not have a picture of what it looked like, I was not sure if it was possible to get an easy out in there without drilling. I thought drilling was a bad idea as a starting point.
Old Jul 24, 2011 | 02:07 PM
Yes,
That is why I said "Old Timer Mechanic's" from the 1950's to 1980"s were the best in past.
I learned from them.
Taught me hundreds of tricks long forgotten by most.
I try to share them with all when the situation or need arises here on C4.
Saying Thanks here to my long time Bud "Bill"/ "Crazy" out loud here on C4 Tech.
He passed on sadly in 2007.
If you guys think I am a "piece of work".....
Bill broke the mold on all.
Was only 1 of him.
It was his trick I shared last 2 days.
Brian
To broken spark
