An Easy Fix?
Old Jul 25, 2011 | 11:03 PM
silveradopower's Avatar
silveradopower
1st Gear
Default An Easy Fix?
Thanks for any help you can give on this!
I recently put an intake gasket set on my 87 5.7L TPI.
It runs out great after re-timing it and reassembly.
BUT...
The electric radiator fan runs continusly and the ses light comes on after about 30 seconds of run time.
The A/C has not worked in years so there is no pressure there and
the coolant is full and working correctly so there is not a heat issue.
I'm wondering if the code being set is triggering the fan or if there is possibly anyone whos had this sort of issue in the past. All hoses and connectors were reattached correctly.
Thanks!
Old Jul 25, 2011 | 11:20 PM
oldalaskaman's Avatar
oldalaskaman
make sure the A/C setting isnt activated on your climate control?
Old Jul 26, 2011 | 08:39 AM
C409's Avatar
C409
..... What are the trouble codes ?? ..................
Old Jul 26, 2011 | 08:50 AM
rodj's Avatar
rodj
Usually means engine is in "limp home" mode.
Refer post # 3 above
Old Jul 26, 2011 | 09:37 AM
Muffin's Avatar
Muffin
rodj BINGOS yet again.
Old Jul 26, 2011 | 10:11 AM
navy_vette's Avatar
navy_vette
I've never heard it called "limp home" mode.
Yep, we need codes.
Old Jul 26, 2011 | 11:29 AM
MyFirst90coupe's Avatar
MyFirst90coupe
Stupid suggestion but make sure you plugged the temp sensor back into the front of the intake.
Old Jul 26, 2011 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
And the MAF connector and IAT connector (under plenum).
To An Easy Fix?
