9th injector
it only gets power when the engine is cranked over and power to the CSI is controlled by a temp switch at front of intake.(Has same plug connector as a injector)
Only supplies extra fuel on cold starts like pulling the choke on a carb car.
If you restarted car and engine temp was below switch setting it would still activate CSI.
No effect on idle.
No effect on idle.
