Battery Master Switch
Old Aug 3, 2011 | 11:55 PM
MBE111's Avatar
MBE111
Default Battery Master Switch
I installed a master switch on the ground cable from the battery on my 1986 Coupe.
When I switch on the battery after the car has sat for a week or so and start it up, it doesn't run very well at first.
Is this because the ECM loses its settings when I shut off the power to the computer (ECM)?
If so has anyone tried one of those 9 volt batteries that plug into the cigarette lighter to keep the ECM energized?
Does that solve the problem?
How long does the 9 volt battery last when powering the ECM to keep its memory?
Is there any issue with shutting down the ECM repeatedly that I could cause damage to it?
Thanks for the information
Old Aug 4, 2011 | 12:02 AM
Pwnage1337's Avatar
Pwnage1337
I'm not sure that you could damage the ECM by resetting it 1000 times,
but I do believe that the reason it runs rough at first because it has to relearn everything.
No idea on the cigarette lighter.
Old Aug 4, 2011 | 12:07 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The kill switch is a great idea.
But, there is no advantage to leaving the system off unless you have a drain on the battery that needs to be fixed anyway.
IMO add a Battery Tender to your garage to keep the battery topped when not in use.
And yes the car is running like crap because the ECM stores "learned" info for the next start.
Old Aug 4, 2011 | 12:30 AM
383vett's Avatar
383vett
As pwnage mentioned, the computer needs to relearn whenever the power is cut. Sometimes it can take 50 miles or so. A 9 volt will work for a few minutes, not a few days.
Old Aug 4, 2011 | 12:42 AM
MBE111's Avatar
MBE111
Yes I have a drain on the battery because it will go dead after a few days to a week.
Sounds as though I can keep switching it off without doing damage to the ECM.
I think it to be a worthwhile effort to try to track down the draw.....something to do in my spare time.
Thanks guys
Old Aug 4, 2011 | 12:46 AM
383vett's Avatar
383vett
Hook up an ammeter between the positive cable and the battery. Check the reading and note the current draw. Pull the fuses one by one untill the draw decreases significantly. You have now found your drain.
To Battery Master Switch
