Cruise Control
Old Aug 4, 2011 | 08:49 AM
81c3's Avatar
81c3
Default Cruise Control
CC stopped working on the 95 6 speed, Whats the procedure for diagnosis? Everything else works fine, brake lights work fine as well... Hoses look good, electrical connection looked good.... what should I look at next?
TIA
Old Aug 4, 2011 | 09:26 AM
aminnich's Avatar
aminnich
If the vacuum side is working correctly then the switch on the clutch/brake pedals is most likely the problem.
Old Aug 4, 2011 | 11:23 AM
69mako's Avatar
69mako
Complete a good inspection of your vacuum lines...even a crack or a broken nipple can lead to problems
Old Aug 4, 2011 | 11:35 AM
STL94LT1's Avatar
STL94LT1
Make sure the vacuum check valve is not damaged. It's under the passenger side fuel rail cover.
Old Aug 4, 2011 | 12:32 PM
Phat98's Avatar
Phat98
Carefully check the vacuum hoses to the servo around the battery, particularly the one going through the firewall to the brake pedal. Both my C4s needed all these hoses replaced.
STL94LT1 also makes a good point - I've seen the nipples on that valve become so brittle they break with just a light touch.
Good luck!
Old Aug 4, 2011 | 04:46 PM
pcolt94's Avatar
pcolt94
Well these posts cover the common and simple items. Just want to add that the switch on the brake pedal is a 3 part switch. You realy got to get it out to verify and check. (TCC, cruise and brake light).
Is this stick or auto?
Old Aug 4, 2011 | 10:04 PM
81c3's Avatar
81c3
Thanks to everyone for the suggestions. Its a 6 speed. Ill go up to my dads this weekend (car is in his garage, mines full) and look at the mentioned places.
To Cruise Control
