GMPP 1.6 RR
Old Apr 27, 2002 | 11:37 PM
djbraxton's Avatar
djbraxton
Default GMPP 1.6 RR
I'll be installing these on my 88 rebuild, will the noise set off my knock sensor? Will I have to get the prom reprogrammed for the extra noise?
Old Apr 28, 2002 | 01:18 PM
WINNER's Avatar
WINNER
Cruise-In II Veteran
Default Re: GMPP 1.6 RR (djbraxton)
You can use an LT4 knock sensor :cheers:
Old Apr 28, 2002 | 01:33 PM
scorp508's Avatar
scorp508
Do you have a carbide bit and a die grinder? Or dremel tool? I had to cut an enourmous amount of material out of my '87 valve covers to clear my comp cam pro magnum 1.6 roller rockers.
To GMPP 1.6 RR
