Hi: This is the 3rd time I've posted a question about a problem with my 85. All were different. Perhaps I should mention that this was a flood car, which explains what I am dealing with here.
Anyway, I had it out yesterday and it ran pretty well. One thing I did notice was that when I started it cold, it started up in a fraction of a second. After driving for about 1/2 hour, turned it off, went into a store and came back to re-start it, it turned over for almost 10 seconds before starting. This is a normal occurance.
How old is the battery and the starter?
As a battery ages it will become harder for it to send 100% power out to turn over the starter. Also batteries don't live long in a heated enviroment
being that its a flood car, plan on having problems...forever
Its a flood car? Holy cow
Flood cars are full of problems, shorts, bad grounds, dirt in connections,
The main issue with a flood car is that even when it is cleaned up...its never really clean, microscopic dirt in the water and even fine silt finds its way into every crack, crany and inside electrical connectors, coating contacts and messing up the path of signals and current flow...a real nightmare...you can scrub, wipe down and clean every place your eye can find...but its not truely clean.
I don't mean to be a buzz kill, just letting you know from past dealings with a flood car...they are a real bitch to trouble shoot
Gosh, I hate to continue the badgering, but a 25 year old flood car, you are doomed forever. The rest of us are fighting these 20+ year old cars as it is...
Could be a lot of things. Start with the simple and work to the more complex.
1. Battery test
2. Starter test
3. Fuel pressure test.
4. Spark Test
5. Scan tool
Don't just throw parts at it is the best advice I can give you. Test and replace only when something tests bad.
Any idea why it is so hard to start when its hot?
Thanks.
Ck the fuel relay.....make certain oil press SWITCH is connected well.
eng coolant sensor.. in the intake under the TB...(there are at least 4 temp sensors, what you see on the dash comes from a different sensor) and wire harness
Flood car or not, it shouldn't take that long to start. If it's still cranking good the battery is probably OK and since it does it often and is repeatable, I'd tend to think it may not be flood related. The first thing we're going to have to know would be where the problem is. How is the fuel pressure and do you have spark? A fuel pressure gauge from Harbor Freight would be a good first step. You'll probably need it more than once in this lifetime.
I'd prefer to think of it as a hard start problem and not flood related. No sense jumping to conclusions. Tape the fuel pressure gauge to your windshield with duct tape and the next time it's hard to start just record the pressure. Since we've got to start somewhere it may as well be there. Good luck. ---Gunny---
My guess, injectors are leaking after a run. It has to turn over a while to clean out the excess fuel. A pressure leak down check will verify the problem. Overnight it has time to leak down and evaporate so it cranks right up.
I have an 87. It had the same problem. A bottle of redline fuel system cleaner fixed it. Don't know if it will fix yours but it's not an expensive try.
All great suggestions. I knew I could count on you.
I can't say when it was flooded. The previous owner never disclosed it to me, but I know it was because of all the rusted parts I've found under the dash.
The battery, starter and all their connections are A1. New spark plugs too. I have been putting injector cleaner in with each fill up.
So eliminating all of these suggestions it leaves me with Fuel pressure test, fuel relay, oil pressure switch, and engine coolant sensor. I think that's all of them.
I'll get on this over the next week or so and will let you know who was the closest.
When it won't easily start, THAT is the time to do diagnostics to find out why it won't start! Engines need spark, fuel, air, and compression in order to start and continue to run. Use a timing light during short cranking to see if you have spark and correct timing. Pull a spark plug boot and bring a grounded wire close to the inside of the boot and see if you have a snappy at least 1/2" spark. Use a fuel pressure gauge and see if the pressure holds up for at least 1/2 hr enigne off. Fuel pressure should be 35-42 psi. Use a noid light to see if the injectors are being pulsed. Spray some starter fluid into the intake and try a start. If it starts you have a fuel delivery problem. I doubt you have a compression problem because you can get it to start and run. If you get stuck somewhere with this condition, hold the throttle full on and crank, this stops the injectors and allows the engine to clear out an over rich condition.
