Towed Home - Opti?
Old Aug 19, 2011 | 09:42 AM
CAJUN C4's Avatar
CAJUN C4
Default Towed Home - Opti?
Wed, night I was ,Luckely, 2 blocks from home and it died.Would not start.It's my 95' with 106K mi.The only thing that hapened differntly was for the past few months every once in while ehen I excelerated from a stop it would give me a little bump. Felt like one plug would misfire??? It pulled to redline without a mis. Then...Gone....I hope it's a coil / ICM or a fuel pump.Anyway ,anyone have simlar symptoms occur????
Thanx
Old Aug 19, 2011 | 10:59 AM
DogAlpha's Avatar
DogAlpha
I replaced my OPTI and it was a real pain.
See if your water pumps weep hole is leaking cause it drops right on the OPTI and rusts the inside.(This was smart Chevy)
Also did you happen to run thru any high water lately or shoot hose water to the front of your engine?
If you can get it to turn over and idle for a fem minutes do it in the dark and open the hood.
Look for sparks coming off of your plug wires.
I had bad plug wires and where shorting out.
My wires looked new but when looking in the dark I could see they sparked and needed replaced.
I would start with plugs and wires first since the OPTI cost around $600 and is a pain to replace yourself.
If you do replace OPTI I think there is a newer SEALED version out there which keeps water out.
Old Aug 19, 2011 | 01:16 PM
Robert Thomas's Avatar
Robert Thomas
Army Hoist Operator
IMO, run the onboard diagnostics, get the DTCs, get an FSM & go thru the diagnostic checks before you start replacing parts. The opti may not be bad. And now you can buy them new for $80, $140, $400.
Old Aug 19, 2011 | 01:27 PM
CAJUN C4's Avatar
CAJUN C4
I agree..Usually the 95' / 96's last a pretty long time.My good friend has very sophisticated Snap On diagnostic equipment and we'll run one on Sunday.
Old Aug 19, 2011 | 01:41 PM
aminnich's Avatar
aminnich
If it quit like turning the key off I would suspect the ICM, especially if it will restart now after cooling off.
Old Aug 19, 2011 | 02:13 PM
HlhnEast's Avatar
HlhnEast
I guess its a good thing you have all those new parts laying around!!
Hope ya get it goin again til its convenient to have it down.
take care!!
Oh yeah, check your fuel pressure and filter. I bought 25 gallons of water once on 59 coming into Mandeville. Man I was PISSED!!
Old Aug 19, 2011 | 02:32 PM
jnealg's Avatar
jnealg
ditto this. I just pulled half a tank of water myself.
Siphon (from the bottom of the tank) some out and check it out in a glass jar.
check fuel pressure (btw, fuel and water show the same pressure on a gauge. ask me how I know
check injector signals
check spark
these are easy checks and I go through them before I even crack the FSM. this could point you to the right system and give clues to investigate.
Old Aug 19, 2011 | 04:21 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If no codes I'd try the ICM and coil. Even if it didn't start after it cooled off.
Also the low voltage harness from the opti to the ECM connector should be checked.
My 92 died like this with no codes. replaced the ICM and coil.
It ran fine until the waterpump took out the opti a few thousand miles later.
Old Aug 19, 2011 | 04:28 PM
CAJUN C4's Avatar
CAJUN C4
Pardon my Ignorance. What's an "ICM" ?
Thanx
Old Aug 19, 2011 | 04:50 PM
STL94LT1's Avatar
STL94LT1
ICM = Ignition Coil/Control Module
Old Aug 19, 2011 | 06:06 PM
SouthernSon's Avatar
SouthernSon
Thanx
Resides just above the coil and against a metal heat sink dissipator, held on by two screws. When replacing, be sure to spread the supplied paste evenly against the back side of the ICM.
Old Aug 23, 2011 | 11:44 AM
CAJUN C4's Avatar
CAJUN C4
Well, went out this morning and it started right up not even a hicup...runs fine. Hot Coil / ICM Suspect??? A Bad Opti wouldn't heal itself when cooled down I don't think??I know a bad coil could....don't know about the ICM???
Comments
Old Aug 23, 2011 | 11:48 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
An ignition coil or an Ignition Control Module can fail when hot.
You would need to follow the troubleshooting diagrams in an FSM.
SAVE the WAVE!
Old Aug 23, 2011 | 12:19 PM
pcolt94's Avatar
pcolt94
Sounds more like an ICM to me also. It is easy to change and takes little time. The coil will take much longer and is more difficult due to the fact the old mounting has to be used and you will probably have to drill out the rivets to get the coil off the original mount.
But if you bought a coil, you can actually just hang it for test purposes and drive normal. It's just one connector and the hot wire.
Old Aug 23, 2011 | 01:46 PM
mfi's Avatar
mfi
If your car has near or over 100K miles..I would replace the ICM and coil regardless..its easy..and you get to clean up the heat sink which is prolly packed with dirt..which is why the ICM's go...you see Chevy at that time semed to like to put parts in places they don't like to be:
Opti under the water pump and behind the damper..nice and hot and wet
ICM right onto the head..nice and hot..they could have put that on the fender..or anywhere...very..strange...
Old Aug 23, 2011 | 01:54 PM
CAJUN C4's Avatar
CAJUN C4
Thanx Guys..I figured as such. It has 106K Mi. I'm gonna change em both.
Thanx Again
Dennis
Old Aug 23, 2011 | 02:38 PM
STL94LT1's Avatar
STL94LT1
Comments
I've had two optis die, and both would restart and run fine once the car cooled down.
To Towed Home - Opti?
Old Aug 23, 2011 | 04:40 PM
CAJUN C4's Avatar
CAJUN C4
Oh Lord ! Well,one can only pray it's the easier of the 3.Shouldn't a code have been set if it's the Opti?
Thanx Guys..I'll let you know how I make out.I do have an MSD Opti waiting if needed.I do believe the Vented 95' - 96's were better though.
Old Aug 23, 2011 | 05:03 PM
1963SS's Avatar
1963SS
The next time it won't start or it just quits here's a little electronic guy tech tip. Go to Radio Shack and buy a can of freeze spray. Keep it in the car. It's like dry ice in a can. Spray it on your ICM and it will cool it right down. Try to start it again. If it starts the ICM is bad.
The freeze spray is the best troubleshooting aid since the VOM. Even a bad transistor or diode will start working when it gets cold enough. Most of the time.
Old Aug 23, 2011 | 08:50 PM
mfi's Avatar
mfi
