Wiring through firewall
Old Aug 20, 2011 | 04:11 PM
Mikky89's Avatar
Mikky89
Default Wiring through firewall
Where is the best location to run additional wiring through the firewall on a 1989?
Old Aug 20, 2011 | 04:54 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Behind the battery, theirs a harness that go's into the interior.
Old Aug 20, 2011 | 09:08 PM
Mikky89's Avatar
Mikky89
Thanks, I will check it out
Old Aug 21, 2011 | 05:01 AM
Cliff Harris's Avatar
Cliff Harris
The cable behind the battery is a huge connector, C100 I think. I don't think there's any way to get an extra wire through there.
The main cable from the ECM to the engine goes through a big seal near the rear of the passenger side exhaust manifold. I think you could get an extra wire through there.
Old Aug 21, 2011 | 11:35 AM
383vett's Avatar
383vett
I just drill holes anywhere; around the throttle pedal cable, under the brake booster, to the left of the clutch pedal. Just make sure there is nothing on the other side that will be damaged. After the hole is made, use a coat hanger with a hook on it to pull your wires through.
Old Aug 21, 2011 | 01:38 PM
The Green Hornet
I did.
Old Aug 21, 2011 | 03:52 PM
HlhnEast's Avatar
HlhnEast
I added an extra ground for my digi cluster. I looked at the area where there is a big connector and went just to the side making sure I wouldnt damage anything else. After I drilled the hole and ran the wire I dabbed a bit of silicon around it to waterproof it.
Old Aug 21, 2011 | 05:46 PM
86vette1sttimer's Avatar
86vette1sttimer
7th Gear
Hello all, I've been lurking here since I bought my car in February but thought maybe I would have something useful to add about this. When I wired in a switch to control the fan I pulled the wire thru the hinge area of the driver door and then thru the grommet for the door wiring. No drilling. Just a thought.
To Wiring through firewall
