04-113 Stage 3 heavy duty stage 3, 6 puck sprung hub clutch kit. This kit is ideal for street and track use in cars rated to 575rwhp. This kit must be used with a solid flywheel part # 198501s (Billet Steel Flywheel) or 198501 (Aluminum Flywheel).
I used the McCleod dual disc in our 600+ HP 427 for several years. Really liked it because it was very compliant on engagement to prevent wheel spin, important on autocross starts, and stock like pedal pressure for my wife when she raced it.
Don't let the picture of our 67 427 confuse you, the clutch was used in a racing only C4.
Reason: Prevent confusion.
I went with a Stage 2+ on my 550chp motor because it was a more DD Friendly clutch than the Stage 3 and I have ZERO Complaints, other than you need to make sure that you have the clutch assembly Balance checked. Do NOT Assume that the Spec clutch will be Balanced properly from Spec, get it verified locally.
the car is an 85 vette, 400cid, dart heads block, tpis mini tpis ZZX cam richmond 6sp 153 tooth flywheel (want to keep for header/starter clearance, 3:73 44 out back 275/17 tires. Will be putting on a quicktime RM-6021 scattershield and putting yet another rear bushing in the trans, thanks for the input guys
Sorry. This is a gutted race car, starting with an 84 Vette frame. The drivetrain is 89-96 vintage type with a ZF transmission so my previous post can apply to the original posters question. Raced it for many years at many SCCA and NCCC events in several midwest states from TX to MN. Sold it to a friend in our Corvette club.
This was told to me just recently and it's very true, "Keep in mind, McLeod will expose the weak link in your combo." Which is that dana 44.
I'm running same HP as you and i chose to go with a full faced Spec stage 3+ semi metalic kit. Haven't driven the car yet but i expect it to preform very well.
I've got a 2pc rear main seal seal spec flywheel, and the stage 3 clutch, pressure plate and throwout bearing from a project a couple of years ago (421 550hp stroker ~similar to yours). I went with the automatic, but never parted with the package from carolina clutch. I might sell it if you are interested. This is a pull (factory) type setup.
my solution to the rear is to keep the tires no wider/softer than I have now and hope for the best
You'll be fine for what you mentioned in your OP, but drag racing is different. Much harder on the drivetrain. Auto-x and RR are harder on everything else, not so bad on the trans/diff.
You will be very happy.
My spec stage 3 + is holding up fine behind 500 rwhp/ 475 rwTQ supercharged car.
My spec stage 2 blew up on me after 11k miles causing a highway tow-home.
Ive heard spec stage 3 ive heard is not-as-streetable as stage 3+ due to its puck vs. disk design of the the stage 2 and stage 3+. Though thats hearsay.
You definitely want a sprung hub type clutch to reduce gear noise and id go with the lightweight aluminum fidanza flywheel for reduced rotational intertia / faster acceleration vs. heavy flywheels.
Other than a slight rattle at WOT or if you lug it up a hill in too-high-of-a-gear, noise is not an issue due to the sprung hub clutch.
Mcleod is great, but ive heard its brutal on c4 drivetrain components (dont think its sprung hub)....
I have the spec 2+ in my 441rwhp 383 lt4.1k street miles and no track use.I miss the smoothness of the dual mass flywheel but once you get used to it driveability is fine.Probably make it to the track this fall.
Need to soften the hit somewhat or the rear axles will not be home for dinner.
