4+3 help
Old Aug 31, 2011 | 08:33 PM
markf726's Avatar
markf726
6th Gear
Default 4+3 help
I have a 4+3, Overdrive only works when car is cold until @155F and then its gone? changed OD relay, still the same! Any Ideas anyone?
Thanks....
Old Sep 1, 2011 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does the OD light stay on while you loose OD ?
Does the switch on shifter turn the OD light on and off ?
Old Sep 1, 2011 | 09:00 PM
markf726's Avatar
markf726
6th Gear
My OD light goes off and if im in OD when the temp hits 155f it shifts out of OD. Any Ideas whats happing?
Thanks for you help.
Old Sep 1, 2011 | 09:02 PM
markf726's Avatar
markf726
6th Gear
Sorry. My button works when the car is under 155f. I can shift in and out of OD with no problems until it reaches that temp.
Old Sep 2, 2011 | 08:58 AM
c4cruiser's Avatar
c4cruiser
For the 87 and 88 OD units, they should not function until coolant temp reaches 122 degrees F. Have you checked the coolant temp to make sure the coolant is the same temp as what is displayed on the digital readout?
You might also check for low fluid. When was the last time you did a fluid and filter change? Another possibility is that the OD solenoid is not working properly.
Old Sep 3, 2011 | 09:05 AM
AGENT 86's Avatar
AGENT 86
First thought that comes to mind is the ECM goes closed loop, then sees something it's not happy with and shuts off OD.
Does the SES light come on ?
Are there any stored codes ?
To 4+3 help
