why is everyone here so hung up on using heavy flywheels?
Why? There is a 12 lb fidanze aluminum flywheel w/ steel replaceable friction surface and steel starter motor teeth.
I am running in on my 93, along w spec stage 3+ sprung hub clutch and it is wonderful.
There is a tiny rattle noise during 1st gear wot, and if you lug it up a hill.
This ain't no cadillac people.
Hot rod did a test in the quarter mile of the same car w a heavy flywheel and a lightweight flywheel.
The results showed that any gains the heavy flywheel had at launch were eclipsed during the big end of the run by less rotating inertia on the motor.
So if you are considering a clutch change, you should also consider lightweight flywheel.
I am very happy w mine.
With the cam I have - At idle my ZF rattle sounds like a Power Stroke. I constantly have folks ask me "whats wrong" or say "Hey!! somethings broke on your car"....
It's not difficult for ME to drive but I've been driving it for a while.
I had the same FW and clutch in it when it was otherwise stock (for over 20K miles) and it had a slight ZF rattle at idle - but the gear noise under acceleration was very noticeable.
IMO, it's definatly not a mod for everyone with a C4.
Will
Driven a few Fidenzas in L98s, modded LT4s and thought they sucked.
Sure you can get used to it but like the stock driving characteristic when it comes to cluches.
Launch a car with a sticky tire on a 12 lber then a 30 or 40 lb.
night and day.
Everyones different
Will
This is a pretty good read and if you care to get more technical there's many good reads out there. There's a place for a light wheel and it's generally not in a 3200 lb car that's street driven or drag raced.
http://www.w8ji.com/rotating_mass_acceleration.htm
heavy wheels mean more stored energy. They absorb that energy as they delay the revving of the engine and return it at higher rpm.
Light wheels mean faster revving from less mass, but also mean less energy returned at high rpm..
heavy wheels are also used to maximize the torque thats produced. They keep the crankshaft turning with inertia when the rods are not transfering energy to the shaft...as in a stall situation or low rpm where resistence equals power.
It starts making horsepower exponentially (due to the boost and cam) at high rpm. Im talking > 6000 RPM.
Yes, a lightweight flywheel - to get me up there is what Im going to need.
I shift lightning fast and I have short throw shifter to help me out there.
A heavy flywheel would have me spinning in circles at the line.
I guess I can see your point, if you have a stock intake l98 motor, then the heavy flywheel - to make the best use of what its designed for (low end grunt) is what you need to get you going.
Now, I do think a heavy flywheel is easier to drive in stop-go traffic. But I try to avoid anywhere with stop-go traffic if im in the vette (no fun to be had there).
There is a formula that helps calculate where that point is, when you have enough HP to be better off with less mass on the crank. Must be toward 1000 where its got power to spare...and able to run one gear down a 1/4.
If you ever come across the engine build formulas and the calculations for some of these variables, run thru some...its interesting stuff. Just bring your calculator or slide rule...
Need $$$$$ too. LOL
Someone posted a link to it here about 5 years ago.
Of course, those 'power C4 users' that were on here then arent really on here much anymore to remember the article...
I have the OEM DM flywheel in my LT4. I like it for the street. It does hold back acceleration as compared to a lightweight FW but it is so much nicer and quieter as a DD. You cannot have the best of both worlds. It simply does not work that way.
Probably the most accurate statement in the whole thread !
http://www.popularhotrodding.com/tec...e/viewall.html
Is this the article your refering too?
Someone that understands it!!
In the old days we used to make super heavy flywheels for the drag applications to utilize the stored energy for the launch.
whats the flywheel weight on a pro dragster that runs 3.xx second 1/4 miles?
Again, the article I read stated that any gains at the start are eclipsed by the freer reving (it takes rpm to make HP) nature of the lightweight flywheel.
Maybe if you are running a station wagon, heavy flywheel is best.
If you are running a lightweight corvette with a 6000+ rpm redline, then light flywheel is going to give you the best 1/4 mile.
How hard/easy it is to launch it (without spinning the tires or the other extreme bogging it) is a whole different subject.
Assume a perfect launch.
I launch in the 1.8's on drag radials w/ my lightweight flywheel.
