Help! It just won't start!
Old Sep 2, 2011 | 02:40 PM
RRPVETTE's Avatar
RRPVETTE
Default Help! It just won't start!
I've been dealing with this for well over a week now, when I turn the key it will turn on all of the electrical components but if I try to start it...nothing, not even turning over. I would have someone check it out but It's kinda stuck in the driveway. I've been told it could be the starter or it could be VATS. The problem lies with the fact that I don't know how to check the VATS because I've never worked with it before and I can't check anything with the starter because I don't know where it is on a corvette. Any ideas on what I can do to get it started again? And does anyone have a picture of where the starter is? Also Ideas on testing thing to figure out what it is would help.
Old Sep 2, 2011 | 02:50 PM
joe paco's Avatar
joe paco
will need more info, year, trans type. no FSM or manual? first try your spare key, move shifter in neutral if it is auto back and forth slighty in case the safety switch is not making contact. if the starter solenoid is not clicking when in start, it is not being energized for a numer of possibles. can be VATS related.
also, all at once? or did it try to start, etc? looking for clues.
Old Sep 2, 2011 | 04:33 PM
stoydido's Avatar
stoydido
starter is the least likely thing wrong. it is under passenger side. take a jumper wire with you, a couple feet long, jump from the small purple wire terminal on solenoid to the main positive cable, on starter, if solenoid clicks and engages flywheel, the prob is that no current is coming to solenoid. finding that root cause is going to take some checking. you have a service manual of some sort? you will need one.
I think the first check in the factory service manual is to check for voltage at that terminal on the solenoid. you can use a meter, but it is only hot with key in crank position. jumping it is quicker.
jc
Old Sep 2, 2011 | 07:13 PM
LannyL81's Avatar
LannyL81
If you have a manual, are you pushing the clutch all the way to the floor?
Old Sep 2, 2011 | 09:05 PM
RRPVETTE's Avatar
RRPVETTE
it's a '92 auto, i dont have a fsm or anything for it, i've tried both keys, i've moved the shifter back and forth, and for about a week or two it was taking a minute to start up if it was warm but then all of a sudden it just quit working all together on the same day that it last ran. I started it at some point that morning then that afternoon/evening it wouldn't start
Old Sep 2, 2011 | 09:07 PM
RRPVETTE's Avatar
RRPVETTE
jc
so I can get to it without lifting it? and i take it that you have no pictures or anything to show me exactly where it is? sorry but i'm new to the vette family so almost everything to do with this car is new to me
Old Sep 2, 2011 | 09:25 PM
joe paco's Avatar
joe paco
by the fsm you start with the solenoid purple wire that comes from the neutral switch, ck for 12v, key in START, meaning you have a second pair of hands. if you have 12v, then solenoid is likely the problem. or, jump solenoid as mentioned earlier. this will be the easiest component to get to, by the way!
if no 12v, trace back to neutral switch, under the console. if no 12v, go to start relay. try the ones mentioned first, in that order. rremember that these are only hot in START mode.
start relay is more complicated, and it will sort out a vats issue or ign switch.
if you had been cranking up to a minute, possible that the solenoid or starter have burned windings. I am assuming that your "nothing" means no click from solenoid, no relays under the dash, etc. to me, nothing is same as waving the key in the air.
Old Sep 2, 2011 | 09:32 PM
joe paco's Avatar
joe paco
unless you are thinner than 10" you will have to put it on jack stands, whatever. NOT the jack that comes with it, solely. you won't miss it. attached to the rear btm eng block, plain view.
sorry, no pictures. follow the exhaust pipes, passenger side, and there it is, wires and solenoid facing front.
Old Sep 2, 2011 | 09:47 PM
oldalaskaman's Avatar
oldalaskaman
before you get to crazy, get a resister the same value as the key and splice it into the two wires(yellow/yellowwhite?) in the knee panel, if it starts get a new ign switch, and key and make sure its the upgraded(longer) version
Old Sep 2, 2011 | 09:58 PM
powerpigz-51's Avatar
powerpigz-51
First things first....try cleaning your battery cables by taking the cables off and using a wire brush on both the cables and battery.
Old Sep 3, 2011 | 03:48 AM
Cliff Harris's Avatar
Cliff Harris
When you turn the key to the start position you should hear the starter relay clicking (inside the instrument panel) and also the starter solenoid clicking (mounted to the starter). If neither of those things are happening, it's probably a VATS issue.
Tell us what you hear and we can proceed from there.
Old Sep 3, 2011 | 12:12 PM
RRPVETTE's Avatar
RRPVETTE
Like I said, I hear nothing that's why I'm confused. It's like the starter isn't even there
Old Sep 3, 2011 | 12:18 PM
oldalaskaman
read for understanding, posts 9 and 10
Old Sep 3, 2011 | 12:45 PM
RRPVETTE's Avatar
RRPVETTE
yeah i did, i plan on doing all of that once i get back in town. out of curiosity, do you know of any cheap places to get a resistor? also what is the more reputable place to get the ignition switch with keys from? what is the "upgraded" version of ignition switches? and finally how do i find out the resistor value of my key? i know that's a lot of questions but as you can tell i'm relatively new to the corvette world
Old Sep 3, 2011 | 12:53 PM
stoydido's Avatar
stoydido
we're assuming the batery is ok, you said the electricals work. do the headlights work? if so the battery should at least click the relays and the starter solenoid. if the battery is low, the lights should dim when key is turned to start -unless the purple wire or solenoid terminal is dead.
my advice is to follow the FSM before you rip the vats apart. per the fsm, a "no crank, no click" root cause process goes to solenoid terminal first, then to neutral switch, then to starter relay, THEN to vats, or to ign switch. of course, trans has to be in park or neutral.
the fact that you were cranking for a minute says that heat could build up, terminals can build up high resistance. you don't want to work backwards to the fsm, my opinion.
Old Sep 3, 2011 | 01:04 PM
RRPVETTE's Avatar
RRPVETTE
the battery is fine, i replaced the battery because i had a bad feeling about it when i bought it. EVERY electrical component works, except obviously it won't start. headlights, interior lights, radio, instrument panel, fan, seats, a/c, doors, windows, mirrors, rear hatch, i mean everything works. and just to be clear i did not literally mean i sat there holding the key in crank for a whole minute. i'm not not retarded i've been around cars and torn them apart and put em back together all my life and i know better than to hold it for more than a few seconds...and oh yeah as i said earlier i have no fsm or anything, but i am looking in to it so thanks for the steps from there
Old Sep 3, 2011 | 01:07 PM
3D87C4's Avatar
3D87C4
You can get resistors at Radio Shack or any electronics store that sells components (Frys, for example).
The ignition switch & key's can probably be purchased from the sponsor vendors, sorry I haven't researched this. I got my key from Amazon.com. I would be surprized if any ignition switches available now weren't the "upgraded" unit.
You can read the resistance of your key with an ohm-meter. If you have more than one key check them all. If any are significantly different that's a big clue. There are charts that will tell you which key to order based on the resistance you measure. You should be able to find one with the search function or ask and someone will post it eventually.
The FSM has diagnostic charts you can follow to diagnose this problem. Take it step by step.
To Help! It just won't start!
Old Sep 3, 2011 | 01:19 PM
RRPVETTE's Avatar
RRPVETTE
about the keys, i'm not sure if it helps but i have the original punch outs from the key ring holes. someone told me that it will help to identify the resistance of the pellet. is that true?
Old Sep 3, 2011 | 01:26 PM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
Is the security light steady or flashing when you attempt to start the car. That right there will tell you if the VATS is acting up.
If VATS is activated (i.e. computer "thinks" car is being stolen and thus deactivates engine), the security light will come on.
If the VATS correctly identifies your key, (I think) the security will not light on.
**TRY THIS** Put the shifter in (N)eutral and then try to start the car. Sounds to me your PRND safety switch might be outtta whack.
Old Sep 3, 2011 | 01:38 PM
RRPVETTE's Avatar
RRPVETTE
yeah the security light will flash wheni open the door, then if i'm not mistaken it stays on when the key is in, i'll double check when i get back on monday but yeahi'm almost positive that it's a steady security light. also i tried the whole neutral thing and it didnt work but maybe that's because of VATS? where is the safety switch at?
