Head Gaskets
Old Sep 6, 2011 | 10:34 PM
weaselbeak's Avatar
weaselbeak
Default Head Gaskets
Hello all I have another question for the forum involving head gaskets. I recently purchased new heads to put on my car and am having them shaved so the combustion chamber is 60 cc's. I was told that I should run a .028 head gasket to help keep my compression close to where it needs to be. I understand this (I think) and thats the route I'm planning on going.
However when I was out at my Dad's I saw where he had a set of metal head gaskets hanging on his wall. He wasn't sure what they were for and didn't have his mic handy to check it. They looked like they were grey and had some kind of coating on them. Are these worth looking into or should I just go with the composites and call it a day.
Thanks for any info.
Old Sep 6, 2011 | 10:37 PM
Pwnage1337's Avatar
Pwnage1337
I would just buy new ones, then you are certain that they are the correct part.
Are the head gaskets on the wall still in boxes with part numbers? That would be the only way i would use them, in the rare occurrence that they would actually be the correct ones for your application.
Old Sep 7, 2011 | 12:41 AM
84wannabezo6's Avatar
84wannabezo6
Usually the head gaskets are measured in the compressed state so measuring them on the bench is not accurate.
Old Sep 7, 2011 | 12:46 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by weaselbeak
I recently purchased new heads to put on my car and am having them shaved so the combustion chamber is 60 cc's. I was told that I should run a .028 head gasket to help improve quench.
Fixed.
After shaving heads, you couldn't be reducing the thickness of the headgaskets to "keep the compression where it should be". You are, in fact, increasing compression...which is not a bad thing.
Running a .028" (Victor?) gasket gets you pretty close to the ideal .040" quench which isn't a bad suggestion. Several people are running those. (Google "quench" if you want to know more.)
Old Sep 7, 2011 | 03:32 AM
weaselbeak's Avatar
weaselbeak
Thanks for the info everyone. yes I'm trying to bring my compression up and had decided to use the .028 for that purpose. I will look for a head gasket for aluminum heads and will veer away from the steel ones.
Old Sep 7, 2011 | 03:51 AM
weaselbeak's Avatar
weaselbeak
http://http://cgi.ebay.com/ebaymotor...item588efbd2b1
These are .025 is that going to be close enough to the .028? I'll need to check the clearances when it's going together. It doesn't say anything in the ad about it being for aluminum heads although it does talk about being able to withstand the motion between the head and the block so i'll keep nosing and just put this on my watch list.
Old Sep 7, 2011 | 04:38 AM
Cliff Harris's Avatar
Cliff Harris
There are two types of head gaskets. One is the composite type and the other is the shim type. The biggest difference is the thickness. Check these guys out:
http://www.summitracing.com/parts/FEL-1003/
http://www.summitracing.com/parts/FEL-1094/
My '86 with cast iron heads came with shim type head gaskets from the factory. When I had my valves done, the machine shop told me not to use the composite gaskets because I would lose quite a bit of compression ratio. He recommended the 1094 gaskets, which are on my car now.
Given that you're shaving the heads, I would use the composite gaskets. Just make sure you're getting the proper thickness (and bore size... ;-).
Old Sep 8, 2011 | 02:21 AM
84wannabezo6
These are the ones im using GM 10105117 .028 pretty cheap composition type for aluminum heads check em out
Old Sep 8, 2011 | 02:30 AM
GREGGPENN's Avatar
GREGGPENN
Interesting, that was the head gasket I'd originally planned to use with a head/cam swap (before I decided to do the 383). When I went to my local (Superior) Chevy dealer, the parts guys went to ask their mechanics about the use of that head gasket in a performance build. They recommended against my using it. Never did get a straight answer why.
In my 383, I used a .040" Cometic (with a zero deck). I believe they're coated MLS.
To Head Gaskets
