Brake Booster Replacment
Old Sep 7, 2011 | 05:28 PM
routesixtysix's Avatar
routesixtysix
Default Brake Booster Replacment
I recently had to replace the brake booster on my '88. I got some tips from forum posts on this and am adding info on my experience.
I got a replacment booster on eBay from an '88 Corvette. Tested it with a long vacuum hose to make sure it worked. I got the master cylinder as well but did not use it.
There are two 13mm nuts and a clip that have to be removed under the dash. I took the seat out to get a little more room. The nut on the right is quite hard to access. The nuts are at the very bottom of this picture which I took straight up with the camera. There was no way I could see them this way while working with them.
I had to use 1/4 inch extensions to get between the brake pedal and the steering column with a swival end. I also bought a set of grip-tite sockets which kept the nuts in place during removal and installation.
[IMG][/IMG]
I found that I did not have to remove the master cylinder to get the booster out. There is enough play in the brake lines to move it out of the way.
[IMG][/IMG]
I did have to unbolt the black support from the frame to the driver side hood latch and move it out of the way after moving the cruise control module out of the way as well.
[IMG][/IMG]
This was not a fun job but doable. Even when the seat is removed there is very little room to work. Several times I had to take a break and come back to the job. I had to feel my way to get the clip back in and it took several attempts to do it.
Old Sep 7, 2011 | 05:49 PM
leesvet's Avatar
leesvet
Nice write up...
Wanted to pass along a on the cleanliness of the engine bay
Old Sep 7, 2011 | 06:53 PM
TRACKMAN2's Avatar
TRACKMAN2
ur garadge has carpet??? or do you work in the living room my wife would love that!!!
Old Sep 7, 2011 | 07:33 PM
3D87C4's Avatar
3D87C4
So...you won't have to bleed the system leaving the master cylinder connected, eh?
I love DIY threads, thanks.
Old Sep 8, 2011 | 12:26 AM
oldalaskaman's Avatar
oldalaskaman
if they are not disconnected , you dont need to bleed
Old Sep 8, 2011 | 10:05 AM
littlesk8cracker's Avatar
littlesk8cracker
nice write up, i also did one for the booster replacement with step by step pics.
on a more important note; im also interested in the carpet! in your garage? hahaa nice
Old Sep 8, 2011 | 11:57 AM
pmihaltian's Avatar
pmihaltian
Slingshot
[IMG][/IMG]
WOW ! Oriental carpet in your garage, Fred? Very
Nice write-up. Thank you.
Old Sep 8, 2011 | 01:56 PM
Flame Red's Avatar
Flame Red
This needs to be made a sticky... Nice...
Old Sep 8, 2011 | 11:32 PM
littlesk8cracker
mines in the stickies
Old Sep 9, 2011 | 12:48 AM
leesvet's Avatar
leesvet
....I want carpet in my garage..
Old Sep 9, 2011 | 04:54 PM
routesixtysix
I get a lot of kidding on the carpet. It's old and threadbare, but I figured it should go under the Vette instead of going to the landfill. It's also got a 6 inch hole in it when a Delco battery started leaking on it.
Old Jan 20, 2012 | 05:33 PM
ChrisWhewell's Avatar
ChrisWhewell
[IMG][/IMG]
Yes, this is what lucky me is staring at right now out the garage. The manual doesn't mention moving that brace but it does appear to need to come out of the way. I've got everything disconnected, the old booster should come right out but for that brace.
Old Jan 20, 2012 | 06:11 PM
JackDidley's Avatar
JackDidley
I did my 87 a couple weeks ago. No need to remove the cruise or brace on the 87. Once you have done it, its not that bad.
Old Jan 20, 2012 | 07:56 PM
cadmaniac's Avatar
cadmaniac
How did you test the booster wih a vacuum hose? I have a used one I would like to test.
Is THAT in the sticky?
Nice write up, and super clean car!!
Thanks...
To Brake Booster Replacment
