lets stop this motor building madness!!!!!!
Old Sep 23, 2011 | 01:30 PM
  #81
TRACKMAN2's Avatar
TRACKMAN2
Originally Posted by rodj
I miss CFI-EFI ; he always made for a " interesting " discussion
you know i was going to post his screen name with that post but i couln't remember what it was you are correct sir!!!!!!!
Old Sep 23, 2011 | 01:36 PM
  #82
TRACKMAN2's Avatar
TRACKMAN2
Ah yes, the roastings between him, bogus, kopvet and others.
Priceless entertainment!
bogus ah those were the days!!!!!!!
Old Sep 23, 2011 | 01:45 PM
  #83
TRACKMAN2's Avatar
TRACKMAN2
builder question #1
your all wrong!!!!! repressurised the cooling system with the intake off no leaks around the head gasket pulled the plugs all are fine
decided to pull the pan and wala!!!! seems the machinist ground right into the water passage when clearancing for the crank then jb welded it .......see this is the sh** im talking about... i gues this is my fault too 409 huh
Old Sep 23, 2011 | 02:52 PM
  #84
WW7's Avatar
WW7
Originally Posted by TRACKMAN2
no water pasages on an lt1 intake
Forgot everyone doesn't have a L98. But I was almost right when I said it could be a crack in the block and it turned out to be a hole in the block..Since the machinest put the hole in the block, then tried to cover it up with JB Weld wouldn't he be liable for the damage and have to give you a new block? Seems to me you have him dead to rights on this one.......WW
Old Sep 23, 2011 | 03:27 PM
  #85
383vett's Avatar
383vett
builder question #1
What did you pay for the build?
Old Sep 23, 2011 | 03:31 PM
  #86
TRACKMAN2's Avatar
TRACKMAN2
yeah but this is one of those cases where after talking to my curent builder not a buisness just a young kid and fellow driver who got the block from a friend of a friend that had a 383 he said the block was already ground.....so my hands are kinda tied..he took pitty on me when my last motor went and said we could build one he has done me many favors and has lots of time in trying to get this thing (car not just motor) to run and work right.... he buy the way so far is the most knowledgable about lt1s and road racing engines that ive met..and taken real time building this motor...he is in negotiation with a major player in corvette racing and is close to signing a deal as one of there technitions....i was suprized he didnt notice it but it looks to be fixable....
Old Sep 23, 2011 | 04:02 PM
  #87
Pete K's Avatar
Pete K
Assuming the guy with the grinder notched the block somewhat evenly, what assurances do you have that one of the other ground spots will not crack later? It is likely quite thin.
There is a solution for your block, but welding up 1 hole is not it.
Old Sep 23, 2011 | 04:07 PM
  #88
TRACKMAN2's Avatar
TRACKMAN2
none but i never do have any even when built by pros you know no warrenty any way just hack it up!!! i have an idea how to fix it your not going to like it but it will work..... goto go have a meeting with a client...
Old Sep 23, 2011 | 04:09 PM
  #89
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I would say the solution is have PeteK build you a block. I've seen pictures and several threads on his builds. It's top notch quality work.
Old Sep 23, 2011 | 04:10 PM
  #90
Pete K's Avatar
Pete K
Good luck, whatever you do. It doesn't matter if I like it. It is your car.
If you want advice, shoot me an e-mail. vrodpete@msn.com
Old Sep 23, 2011 | 04:12 PM
  #91
Pete K's Avatar
Pete K
I appreciate the kind words. He may not need a block though. I have solved that problem (hole in the pan rail) reliably, and somewhat inexpensively.
Old Sep 23, 2011 | 04:51 PM
  #92
1963SS's Avatar
1963SS
I'll bet this isn't the first time that someone has struck water while clearancing an engine. I'll also bet that this won't be the last time that someone will use an inch or so of Hardblok or Moroso block filler to fix that problem. The block will have to be re-honed but the problem will go away. No more water leakage.
Old Sep 23, 2011 | 06:22 PM
  #93
TRACKMAN2's Avatar
TRACKMAN2
all the damage is outside the cylender im going to use silver solder.. its more adhesive than epoxy i dont really trust them.....the solder build up nice goes on realativly low temp much lower than brazing or welding but will hold up to a higher psi and temp than epoxy..if a rubber hose can contain water this will definatly work...and if it dosent we will just pull the pan and try somthing else....i doubt a little water in 14 quarts of oil will hurt anything i will check the oil for water after every run...i think ill sleep good tonight....
Old Sep 23, 2011 | 06:27 PM
  #94
TRACKMAN2's Avatar
TRACKMAN2
talked to my builder he said it might of held if he wouldnt of cleaned the block so well he sayed he used solvents and pressure washed and steam cleaned the crap out it probibly weakening the epoxys grip or strenth...i was happy wiyh that answer....
Old Sep 23, 2011 | 08:22 PM
  #95
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Silver solder is a good choice. It is a tad pricy but it will hold up. I had an engine blow a head gasket between two cylinders once while drag racing. When I tore it down I had about an 1/8 inch of material gone off both the head and the block. An old welder I knew fixed the gaps with silver solder and I was back racing the next weekend with the same engine.
Old Sep 23, 2011 | 09:37 PM
  #96
TRACKMAN2's Avatar
TRACKMAN2
it worked... then i coated it with some jbweld just to give it some mass
Old Sep 23, 2011 | 10:14 PM
  #97
cumbercr's Avatar
cumbercr
Originally Posted by 87 vette 81 big girl
TPI Jim 421.
I forget Jim's last name.
He lives in Utah.
A longtime mechanic like myself.
Jim has completed numerous longblock engine builds for other members here on C4.
He seems to specialize in street - strip performance engines.
Very likely can do a full tilt road race engine build for You.
Road race engines are some of toughest to build.
They have to last hours at a time of wide band power ranges,
encounter high G forces that play havoc with wet sump oiling systems.
Accusump is a band aid temporary fix to me.
I know you feel different about that.
If you put $30 K into an engine for road racing ?>>>>
What is another $2 to 3K thousand to spend on a Dry sump Gilmore belt driven oiling system, lines & fittings, Oil & Air-artion separator holding tank with a nice Earl's Oil cooler ?
They dry sump piston powered airplanes for a very good reason too>>>
Wet sump impossible to work with under such operating conditions also.
Airplanes keep on flying with the dry sump oil system.
No Main & rod bearings lost in the engine spinning the propeller.
TPI421Vette built my 396. I think someone mentioned balancing as a key to long life. Jim had mine balanced to 1/2 gram. This is one smooth running engine that should run for a long time. But Jim can't control how I drive it or tune it or maintain it. In other words, how could he warranty what I will do to it. He can't. But I would recommend him to anyone.
To lets stop this motor building madness!!!!!!
Old Sep 23, 2011 | 10:37 PM
  #98
87 vette 81 big girl's Avatar
Are you planning on a complete new engine build ?
Or using your current short block & heads ?
All the problems you have had with this motor,
most would be scared to touch it.
Motown iron block a good choice for the money spent.
Old Sep 23, 2011 | 10:42 PM
  #99
TRACKMAN2's Avatar
TRACKMAN2
iv heard enuff excuses on behalf of the builder what about us the customer??? wait till you spend $40,000 and still dont have an engine that runs ....gm covers their motors iv had a 02 zo6 for years now thousands of track miles allways cool always runs. you know why..... ther good at building engines!!!!!!!! ive not been able to make it fail and believe me ask anyone whos seen me drive im not easy on it...... i not saying i want a warranty im saying we all deserve one....i suspect if it was required buy law...like in my buisness ..some how i think there would be less failures and ultimatly less incompetent builders!!!
Old Sep 23, 2011 | 10:50 PM
  #100
TRACKMAN2's Avatar
TRACKMAN2
hell no im just going to patch it up and go...dont worry i dont have to stand behind my work!!!!!!!! and ill bet it will last for years!!! if it last one year ill be extatic... what the heck its a good block just has a few holes in it. good rotating assmbly save for a few busted up pistons and what else do you need for a good road race motor ask most engine builders and they woulnt tell you they have no idea!!!!!!!!
