1988 won't start
Old Sep 21, 2011 | 10:12 PM
ctrain22's Avatar
ctrain22
Default 1988 won't start
I just purchased an 1988 convertible. But it won't start. Engine cranks, but acts like no gas. Security light blinks when I open the door and while crtaqnking motor. Will almost fire if I spray some starter fluid into air intake, but won't stay running. Could it be something with the security system? What should I check for? This is my first C4.
Old Sep 22, 2011 | 12:23 AM
oldalaskaman's Avatar
oldalaskaman
I dont think its security, I lean to fuel delivery, plugged filter, fuel pump not running, bad relay, after that , it starts to get spendy. when you first turn the key on , do you hear the fuel pump energize. There's an entire thread hear someplace about what a fuel pump sounds like when it energizes, to me it sounds like an agressive, sensual woman in a dark bar that grabs your a$$ an says 'hey, lets go', and when the engine starts , you 'go' . Just my personal opinion though. Did you buy it not-running? or did it quit after you got it home?
Old Sep 22, 2011 | 01:39 AM
rodj's Avatar
rodj
Originally Posted by ctrain22
Engine cranks, but acts like no gas. Security light blinks while crtaqnking motor.
VATS
Read
http://www.thirdgen.org/vats_passkey_system
VATS takes out both the starter and injectors but it is possible a previous owner bypassed the starter relay which would give the crank /no fuel cond you have if VATS was faulty.It is also possible for only the fuel part of VATS to be faulty
Old Sep 22, 2011 | 03:11 AM
Cliff Harris's Avatar
Cliff Harris
I'd check for fuel pressure first before getting into the exotic theories and guessing games we all tend to play here...
Old Sep 22, 2011 | 03:34 AM
navy_vette's Avatar
navy_vette
Keep it simple.
Before you turn it over, do you hear the fuel pump? You'll just hear an electronic "wirr". There is a fairly funny thread somewhere around here where people were "demonstrating" what their fuel pump sounded like.
If you don't hear the pump, it could be the FP relay, Vats, the pump itself, all sorts of possibilities.
I'll predict that you will hear the pump running. Go to a parts store and get a fuel pressure gauge. They are easy to use and one of the BEST diagnostic tools you can buy. Let us know what your pressure is.
Old Sep 22, 2011 | 04:13 AM
rodj's Avatar
rodj
VATS has nothing to do with the fuel pump
Old Sep 22, 2011 | 04:17 AM
rodj's Avatar
rodj
before getting into the exotic theories and guessing games .
Nothing exotic
OP stated
" Security light blinks while cranking motor."
"If an incorrect or no key resistance is read by the VATS decoder module, the module will shut down the start enable and ECM signal outputs for 4 minutes.
The SECURITY light will flash during the cranking attempt "
Old Sep 22, 2011 | 09:27 AM
joe paco's Avatar
joe paco
Originally Posted by rodj
Nothing exotic
OP stated
that's how I read the 91 fsm, rodj. FP is not affected by vats. it's easy to get sidetracked, the system is so complex. don't know if the 88 had a CCM or vats module, but have read that the ccm circuits to enable start relay and enable injectors -which are separate- can fail separately. one poster said he traced it to a terminal backed out of the ccm module.
also, my 91 security light is ON steady while cranking if key is not read, so says fsm, 9-d-3. I had a key read issue for one attempt, but don't recall if it was flashing or steady. have read about the flashing light, somewhere, but can't find it in that chapter.
I agree: the security light on or flashing is a good clue. I guess the OP tried a spare key.
joe
Old Sep 22, 2011 | 10:35 AM
rodj's Avatar
rodj
88 has the independent VATS module but has same two components ;
starter and fuel enable.
Usual diagnosis is , if it cranks , then it is not VATS related
but guys have had problems in the past where the key has been read correctly by the module but one part of it ( or as you state , the wiring to ) has been faulty leading to a wrong conclusion.
Old Sep 22, 2011 | 10:39 AM
hooked073's Avatar
hooked073
88 security light has noting to do with vats at all no relation
Old Sep 22, 2011 | 11:57 AM
ctrain22's Avatar
ctrain22
Thanks everyone for the input. That's what I love about this forum. The members. Been on here for a while, but in the C3 section. My first time in a C4.
Bought it not running, although PO said it ran. I know the starter has issues because when you first turn key, all I get is a clank noise as the starter tries to engage. Bendix going in, but won't crank unless I keep turning the key on and off about 10 or so times, then if I hit the right spot, it cranks. I don't know if that might have anything to do with not firing. I don't really here the fuel pump when I turn the key into on position. I am going to put a new starter in first and go from there. Where are the relays or fuses I can check to see if that could be part of problem?
Old Sep 22, 2011 | 01:06 PM
joe paco's Avatar
joe paco
you may have the denso starter. you're on track, solenoid pulls in bendix, but starter motor is not energized, maybe from the solenoid, which is where it gets power. could also be loose connections, if the owner had messed with it. when starter is in the circuit, the lights on dash would flicker, headlights would dim.
in the 10 times, did the security light flash? don't believe it would, since engine cranks. if vats was preventing crank, there is no click. of course. once engine is rotating, dist is sending pulses to injectors -or supposed to be. monitor your tach to see if you have action, bouncing needle, etc, while cranking.
you can verify all fuses in the main panel. but sounds as if you have two different problems. "click, no start," "cranks, no run."
my experience, the FP motor is not easy to hear, esp if it has the muffler areound it. can be confused with ABS and SRC systems located behind driver seat. stand at tank and have someone turn key on. it will run for 2 secs and shut off, every time key is switched on, but not cranked. will remain on if engine is cranking.
Old Sep 22, 2011 | 02:17 PM
oldalaskaman
fp relay at back of car underneth thar plastic piece that the rear hatch sits on
Old Sep 22, 2011 | 02:26 PM
ctrain22's Avatar
ctrain22
You guys are great. I will keep you posted as I go further. Thanks
Old Sep 22, 2011 | 03:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
FP relay is on the firewall, beside booster.
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old Sep 22, 2011 | 03:22 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Sep 22, 2011 | 03:25 PM
oldalaskaman
darn, I answered another email in this thread, very sorry, bob
Old Sep 27, 2014 | 06:17 PM
spartangreek's Avatar
spartangreek
Default engine cranks but won't start intermittently
just bought 1988 coupe with 4+3. brought it home and made a stop. got back in and it wouldn't start. after 4 hours it started right up, drove it home started up in the morning and two more times then drove it to parts store and it started up again. drove and made another stop and it would not start while cranking again. waited 10-15 minutes for three attempts and still no go. It just barely starts to fire, for 1/2 second or so and quits. after initial try it just cranks wit no attempt to fire at all. Towed it to chevy dealer. previous owner just recently had this work done at dealer:
cleaned throttle bottle; new EGR valve; New o2 sensor; tune up, wires, cap, rotor distributor all replaced; 3 new catalytic converters; new burn off relay; ( air filter, fuel injectors, fuel pressure, fuel pressure regulator, coolant sensor all checked and "OK"
could this be the cylinder lock, bad keys, vats, ignition control module? the dealer noted that the coil showed signs of arcing but nothing was done about it. Don't want the dealer to run up a big bill spinning their wheels here....please help!!!!
spartangreek
Old May 16, 2024 | 06:39 PM
jsinga's Avatar
jsinga
Air spark & fuel basic stuff
TPI terminal G of ALDL will provide power to fuel pump
pull return line at tank look for clean gas
If no spark either module or pick-up in distributor
pick-up run around 500–1000ohms
got to have 12v at big red wire on distributor
you’ll have to find coil resistance
if you think injectors aren’t firing shoot some starting fluid down the intake and see if it sputters
have fun!
My 87 needed a pickup coil and sat for 3+ years started right up when we rehabbed distributor. We cleaned out tank and ran fresh fuel through the system
JS
To 1988 won't start
