Replace targa top bolts?
Old Nov 1, 2002 | 05:40 PM
WAY2FAST's Avatar
WAY2FAST
Default Replace targa top bolts?
The previous owner also managed to partially strip the drivers side Torx bolt that attaches to the top. I can get the top off, but it is hard to get enough on it to keep it securely tightened. Is there a preferred supplier for a replacement bolt and/or what is the procedure for replacing it?
Thanks!!!
:D
Old Nov 1, 2002 | 06:19 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Replace targa top bolts? (WAY2FAST)
That torx screw is a captive screw in the mounting block. I would think youll have to replace the whole mounting bracet. Try a used part place like Contemporary corvette. Its not hard to do.
Old Nov 1, 2002 | 06:26 PM
fullboogie
Default Re: Replace targa top bolts? (blk90rdstr)
Actually, the screws DO come out, and are replaceable. Look at the Eckler's website - they sell these screws for a few bucks.
Old Nov 1, 2002 | 08:27 PM
Chief Muktar's Avatar
Chief Muktar
Default Re: Replace targa top bolts? (fullboogie)
Ya their really easy to replace, they are held up there my a palstic case. Its super tight to get it off, but it does come off. I've had mine apart a few times :cheers:
Old Nov 2, 2002 | 09:07 AM
C4ForGeeGee's Avatar
C4ForGeeGee
I purchased 4 bolts via my dealership after I determined that the drivers side bolt was stripped. I have 3 on stand-by in the car, because know won had them in stock when I needed them. With that bolt missing, it was a very unpleasant sounding ride :smash:
Old May 14, 2024 | 03:27 PM
wbucur's Avatar
wbucur
4th Gear
how do you get the old on out in the front drivers side?
Old May 16, 2024 | 08:10 PM
scorp508's Avatar
scorp508
Melrose Tops has a lot of parts.
C4 1984-1996 Corvette Roofs Parts & Accessories – Melrose T-Top International (melrosetops.com)
Old May 16, 2024 | 08:56 PM
s carter's Avatar
s carter
You loosen bolt and when it's in that wiggly state pull back and turn and get the threads to grab and unscrew.
Putting back together self explanatory
To Replace targa top bolts?
