94 power antenna nightmare
I then decided that I would try to find a used, but serviceable entire unit to replace it with. I found one... $50 out of a wrecked 92. So, I rejacked the car, removed the fender skirt again, and then removed the old antenna unit once more. I did not want to cut any power cables so I traced the cables from the antenna through the body grommet up into the channel by the rear window. It was at this time I discovered that the wiring harness on my replacement motor was larger and flatter than the narrow original one in the car. There were still only three wires on the new male connector, but different colors than the original. I noticed on the 94 female harness in the car that the wires were listed as "A" (orange), "B" (Green), and "C" (Black)... the male harness replacement was also listed as follows: "A" (Gray), "B" (Green), "C" (White). My dilemma was what to do... the two harnesses would not fit together, and other than the harness, the old and new units looked absolutely identical. So I risked it... I cut the male harness off the replacement antenna and attached the male harness of my old antenna as follows: "A" (Gray to Orange), "B" (Green to Green) and "C" (Black to White). I then electrical taped the connection to ensure it wouldn't short out to each other.
Then, I carefully installed the replacement unit in the fender well... however, by this time, I think I screwed it up somehow... I don't remember which grounds were attached to the top of the antenna mast... therein lies one problem, I am sure. I am also not sure what needed to be on what side at the top of the mast. I did the best I could and got it all together, hopeful that I did it right... so I tested it.
I turned the ignition on, turned the radio on, and watched the new antenna rise out of the rear fender.... success, I thought! It rose, and rose and rose... nylon chain and all to my horror! The antenna popped out and unceremoneously lay on the ground next to the car jack!!! If that wasn't bad enough, my bose radio was not making a sound, although the radio was clearly on and locked on a channel... !!! My poor wife heard my expletives all the way in the front yard as I just wanted to throw the antenna into the neighbors yard for their pit bull to eat!
Sorry for the length, but I need some advice... besides let a professional do it. Here is where I am at.
My radio is still not making a sound, although has power to it and it turns on. Could this be a ground I misconnected underneath on or near the unit?
Why did the antenna eject... it should have stopped when it extended? It appears the antenna and nylon chain did completely, and I mean 100% eject... it looks like the entire thing came out and left nothing in the unit itself.
The motor was still running until I disconnected the harness... Did I connect the male harness wires correctly or did they switch when the harness changed... (I know I must have gotten the power wire right as I did have power!)
Could all of this be due to some misconnection of the ground wires to the unit... if so, could someone walk me through which ground wires go where... a picture or drawing would be incredibly helpful...
Any other thoughts or ideas would be greatly appreciated! I have almost 12 hours into this project and have just decimated my self confidence that I can solve this... something that "appeared" to be so easy... yeah right!
In a word... Help...please... before I lose the rest of the hair on my head!
Last but not least... is there anyone in San Antonio, TX who might have a line on someone who can tackle this problem if I can't... need a good recommendation... both for the radio, and the antenna. Many thanks in advance guys... Randy
The mast should not have come out if the nut was on to secure it.
PM me an address to ship to.
P.S. I did not have to remove the wheel or any skirts when I did mine. I just got a whole lot of dirt in my face! lol
http://www.corvettemagazine.com/body...1984-1996.html
http://www.vetteweb.com/tech/vemp_02...air/index.html
Many thanks for the help... it still isn't totally fixed yet, and "whitenow" actually offered the right solution which I am going to decline at the moment. My radio works (the 20AMP fuse blew when I connected the antenna) and I can manually raise and lower the antenna so car washes are no longer a problem... guess I am content. I will ultimately try this again sometime in the future, but not now. Twice is enough for the time being... again, thanks all for the advice and references...
I like wise have recently purchased a 94 corvette. The radio had been replaced and they had failed to connect the wire that triggers the amp for the Bose Speakers. I was able to locate that relay and wire that to work. I have not been able to locate the relay for the antena. Where was this relay located on your 94? I have also been told that 94's have the relay built into the antenna. Can you confirm or deny?
Barry
http://forums.corvetteforum.com/c4-g...y-surgery.html
