85 vette sensor
Old Oct 4, 2011 | 10:31 PM
terry82's Avatar
terry82
Default 85 vette sensor
on the passenger side of the motor between the last two clyinders.is a sensor ,that is not connected .what is this?
Old Oct 4, 2011 | 10:35 PM
Pwnage1337's Avatar
Pwnage1337
Its a coolant temperature sensor.
Old Oct 4, 2011 | 10:44 PM
terry82's Avatar
terry82
i thought the coolant sensor was on the other side between the first two clyinders.the temp gage works.this sensor is not connected .is it for the computer?thanks for the reply.
Old Oct 4, 2011 | 11:03 PM
rodj's Avatar
rodj
this sensor is not connected .is it for the computer?.
What most on here refer to as the CTS ; coolant temp sensor ( 2 wire unit for the computer )
is at front of intake under the TB.
On a 85 ,as you correctly state, the drv side sensor ( 1 wire ) is for the coolant temp gauge ,
the pass side unit is the temp over ride switch for the fan.
85 only had ECM control of radiator fan but with a mech override switch.
Old Oct 4, 2011 | 11:07 PM
terry82's Avatar
terry82
thanks for the info
Old Oct 5, 2011 | 04:29 AM
gerardvg's Avatar
gerardvg
Hi
I also have an 85 vette, the ecm controls the main fan at 100deg c also when the a/c is running .
the the sensor on the dipstick side of the engine is for the booster fan,
it will ground to turn on the booster fan (in front of a/c condenser) at 115 deg c. check if you have the small booster fan, look in front under bumper.
To 85 vette sensor
