Rear Break Issues
Old Oct 6, 2011 | 01:23 PM
TheTurkTvrdik's Avatar
TheTurkTvrdik
6th Gear
Default Rear Break Issues
I recently replaced my starter on my 1990 convertible and while giving the car a bit of gas to drive up the car ramps, the ramps gave way and began to slide forward. Consequently I hit the breaks hard and to my surprise the car continued to slide. The front wheels locked up nicely on the ramps but as the ramps continued to slide forward so did the car and the rear wells rolled on the ground as if i had never hit the breaks. Eventually the car slowed to a stop after sliding about a foot and a half. The roll lasted about as long as the car was above idle. Is this a common problem among C4's or is it not a problem at all and is just the way it is with the high torque of the L98? Anyone else experience this?
Old Oct 6, 2011 | 01:36 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Without a bias spring the rear brakes do about 10% of the braking
Old Oct 6, 2011 | 02:24 PM
TheTurkTvrdik
6th Gear
Thanks, clearly I still have a lot more to learn about my car.
Old Oct 6, 2011 | 02:27 PM
Fred@ReverseLogic's Avatar
0Fred@ReverseLogic
Former Vendor
Default Time to upgrade to no-slide Race Ramps
Safety first is one of the best reasons to invest in a set of Race Ramps. The incline is so gradual that you barely realize you are climbing the ramps and there is no need to slam on the brakes to stop on the platform.
Originally Posted by TheTurkTvrdik
I recently replaced my starter on my 1990 convertible and while giving the car a bit of gas to drive up the car ramps, the ramps gave way and began to slide forward. Consequently I hit the brakes hard and to my surprise the car continued to slide. The front wheels locked up nicely on the ramps but as the ramps continued to slide forward so did the car and the rear wells rolled on the ground as if i had never hit the breaks. Eventually the car slowed to a stop after sliding about a foot and a half. The roll lasted about as long as the car was above idle. Is this a common problem among C4's or is it not a problem at all and is just the way it is with the high torque of the L98? Anyone else experience this?
Old Oct 6, 2011 | 02:29 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
E-Brake
E-Brake
To Rear Break Issues
