C beam difference
Old May 3, 2002 | 05:40 PM
GRX's Avatar
GRX
Default C beam difference
Does the L98 auto tranny come with a different C beam than the 4+3 or ZF?
Old May 3, 2002 | 05:47 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: C beam difference (GRX)
Yes. The auto and manual C-beams are different length.
Old May 3, 2002 | 10:07 PM
Rich B.'s Avatar
Rich B.
Default Re: C beam difference (Vette92)
I thought that was odd, so I'm checking the parts book...
There's 3 different C-beams from '84 to '91...
Support, Driveline (1984)(1985 A.T.)(1986-91 exc G87) 14091265
Support, Driveline (1985 M.T.) 14084007
Support, Driveline (1986-91 G87) 14091264
G87 is the 8.5" ring gear (Dana 44?) and G89 is 7.5" ring gear (Dana 36?)...So that would seem to be correct...
1985 M.T. seems to be unique... :crazy:
[Modified by Rich B., 9:09 PM 5/3/2002]
Old May 6, 2002 | 10:02 AM
GRX's Avatar
GRX
Default Re: C beam difference (Rich B.)
So the ZF 6speed uses???
Old May 6, 2002 | 06:15 PM
Rich B.'s Avatar
Rich B.
If you believe the parts book, the 4+3 and ZF use the same c-beam. I've read posts here from auto-to-ZF users who simply re-drilled the holes in the c-beam for the new trans/diff hole location, so I'm guessing the auto c-beam is the longer one. So if you're looking at picking one up, the auto c-beam could be used in either configuration (with maybe some new holes).
Anyone else? :chevy
Old May 7, 2002 | 02:16 AM
Bill Reid's Avatar
Bill Reid
Yes...
The auto tranny c beam is about an inch longer... with the auto driveshaft about 1/2 inch longer. I've done the conversion from Dana36 to Dana44 and used manual tranny c-beam and driveshaft when I converted...
Old May 8, 2002 | 10:58 AM
GRX's Avatar
GRX
Thanks for the help!
To C beam difference
