[Electrical] Sitting current draw
Old Oct 19, 2011 | 08:16 PM
mgafun's Avatar
mgafun
Default [Electrical] Sitting current draw
'88 Vert
Ignition off, door open, courtesy lights on:
I = 4.3 amps
Door closed, c0urtesy lights off:
I = 2.2 ma
2.2 ma seems awfully low. Can this be true?
Old Oct 20, 2011 | 01:25 AM
Cliff Harris's Avatar
Cliff Harris
Could be true. As far as I know, the only current draw with everything off is the ECM standby current to keep the RAM alive while your baby sleeps.
Old Oct 20, 2011 | 05:03 PM
mgafun's Avatar
mgafun
The reason I wondered is that I've seen on the forum that the max standby draw can be 50 ma and be normal. Maybe later C4s?
Old Oct 20, 2011 | 10:43 PM
93Rubie's Avatar
93Rubie
An earlier car would have less. A good thing. As long as you are getting the reading correctly and your meter is in the correct range 2.2mA is great. Seems low yes, but if so great. Even if it was 22mA that would be fine.
Old Oct 21, 2011 | 12:47 AM
mgafun's Avatar
mgafun
OK. Thanks for that. I checked it because the battery needs to be recharged if left for 3 weeks even in a solar trickle charger and thought there might be an unusual drain going on. Will have the battery load tested.
Replacement battery with side posts is difficult to source and VERY expensive in this country.
Old Oct 21, 2011 | 06:19 AM
ddahlgren's Avatar
ddahlgren
I am surprised side post batteries are so hard to find in the US I don't think there is a car made that did not use them for the last 20 years. Your battery probably has an internal short that is discharging the battery. If it is over 5 to 7 years old it is just over and time for a new one. Parts age out as well as wear out. Think anything that has any kind of rubber and many plastics plus anything that has to cycle off and on everytime you run the car.
Old Oct 21, 2011 | 07:03 AM
impact1968's Avatar
impact1968
You can buy screw in style side posts for a non post battery. I use them on mine. They cost a few dollars around here.
Old Oct 21, 2011 | 11:58 AM
engle1147's Avatar
engle1147
This isn't a "fix" but it might be an option if the problem persists.
http://www.summitracing.com/parts/GRN-780800-M/
Old Oct 21, 2011 | 12:58 PM
MK 82's Avatar
MK 82
Does his screen name suggest that he may not be in THIS country??
Old Oct 21, 2011 | 02:38 PM
ddahlgren's Avatar
ddahlgren
Yes but the country very close to THAT COUNTRY do make cars along with GM and Ford so can not imagine the problem. BTW my eyesight is VERY GOOD!!!!!!
Old Oct 21, 2011 | 04:27 PM
mgafun's Avatar
mgafun
The only local battery distributor, Exide, that lists any has only one for a ridiculouly high price. I'll try a Holden (GM) dealer. BTW, THAT COUNTRY is 3 hours away by air to its closest point.
Old Oct 25, 2011 | 12:52 AM
MK 82's Avatar
MK 82
The only one who mentioned the US is you.
Old Nov 11, 2011 | 11:40 PM
mgafun's Avatar
mgafun
Default Final followup
The Ford and GM cars made in that country did not have side terminal batteries (checked out at parts depts. of both).
Load test: down to 1/2 capacity. Replaced it with an Endurant 75/650, Group 75 side terminal, 650 CCA. Not cheap here.
New multimeter reveals resting draw is 42 ma. Verified by electrician.
My solar panel is fine. Puts out 75+ ma. Found that the cigarette lighter receptable I had hard wired into the battery was defective, so it was getting no trickle charging at all. Replaced it with a new marine-quality one and now have two 1.5 watt solar panel tricle chargers, the other going to the in-car cigarette lighter receptacle. Battery voltage goes to 12.75 overnight and goes to 13.02 by sundown.
So, new battery, new multimeter, new receptacle solves the mystery. All it took was time and money, as always.
To [Electrical] Sitting current draw
