Won't run warm
Checked the fuel pressure, 39 psi, good according to the book. Checked for codes, none present. I did pump most of the gas out of the tank when I replaced the pump, but there was still some left. It did smell pretty bad.
Any suggestions would be greatly appreciated...
Mike
Mike
Beyond that, the injectors were junk from the factory so plan on those being bad after a 2 yr soak in ethanol. O2 sensor probably needs to be replaced...the shift to closed loop cannot happen with a tired o2 sensor. As it warms it'll die. What are the stored DTCs? pull 'em and post 'em.
Then d/c battery for 30 sec and try again...
Mice in the wire harness...
MAF? Temp sensors checked?
TPS set?
Vac leaks checked and fixed?
Base timing set correctly...clean dist cap & wires.
Lots to do to a motor that did a 2 yr stretch in alcohol.
Poor O-rings...thats abuse.
Most important of all, you need a FSM before even thinking about a real diagnosis.
Do a search here for the link and order today.
I DO think there were critters under the hood, I may have a mess on my hands. It seems odd that there are no stored codes........
No codes is kinda strange.
