85 MAF problems
Old Oct 23, 2011 | 03:46 AM
rsfire's Avatar
rsfire
Default 85 MAF problems
My car has been running pretty weird lately and I'm throwing codes 33 and 34, both MAF caused ones. I finally ended up buying a re-man MAF from autozone and tried it out.
When I put the new one in the cars idle dropped down to 300 rpm or so, drove smoothly and normally under light throttle. But under heavy throttle it climbs up to 2000-3000 rpm or so and feels like it hits a cap and can't climb any higher. It kinda softly backfires out of the intake and just quits accelerating. It also runs super rich the entire thing. The car stinks of raw fuel and my gas gauge that would typically read mid teens at a certain speed shows 4 to 6 at the same speed.
I also noticed with my stock MAF, the car runs like crap and backfires heavily out of the intake while cold, and drives almost normally once it's warmed up, runs like that whether my stock MAF is plugged in or not. So it seemed like my stock MAF isn't connecting, but then a new MAF runs really bad.
Does anyone know if that sounds like some sort of fail-safe or weird mode that the MAF may be causing, or if some sensor has something to do with it?
Old Oct 23, 2011 | 08:14 AM
tunedport85inject's Avatar
tunedport85inject
No codes with the new MAF,85 has the one year MAF module ,inside the dash ,passenger side where the ECM is located.May be a bad MAF module.Probably you have to re-learn routine in your ECM after this problem,trying to run the car and force her to re-learn driving for a while under different throttle load,may be a temporary condition.Does this condition force a limb mode in ECM?ergo you have a rich F/R...just some ideas,wait for guru advice...
Old Oct 23, 2011 | 11:23 AM
Muffin's Avatar
Muffin
A quick glance at my 85 FSM tells me your problem could be in either your ECM, Burn Off Module, MAF or any of the associated wiring. That is what my old boss would call a B.F.O., a Blinding Flash of the Obvious. Trouble shooting is kinda complicated and requires the FSM. You need to find a copy. If you can not let us know, maybe we can work something out.
Old Oct 23, 2011 | 11:42 AM
Hole-Shot's Avatar
Hole-Shot
Stop on over by me. I can get that smoothed out for you, and I can get those locking lug nuts loose too.
An impact wrench will loosen them up pretty easily.
Old Oct 24, 2011 | 11:28 PM
rsfire's Avatar
rsfire
I assume by MAF module you are talking about the burn off module? That is for sure one thing I think may be causing it, I just need to track one down to test it.
And you said it may take a bit for the ECM to re-learn the routine, do you know if that is something that will be done in a few hours or a long time? I drove it around town the day I tried that maf and left it on over night and tried driving it around the next day but nothing got better.
Yeah I'm wondering if something is causing the car to go into a limb mode, that what it almost seems like to me. But I for sure wouldn't know
Old Oct 25, 2011 | 05:43 AM
tunedport85inject
example:
When your batt goes wrong,and you go with a new battery,then the ECM have to re-learn,but it requires not more than 1 hour driving the car around town to complete self-lerning cicles.
If you had driven the car for so long time with no better results,than,new MAF haven't solved the problem.Code 33 -34 are tipically MAF sensor output voltage related problems.There's an invalid relation betwen MAF output and TPS output. ECM sees an High voltage (more than 90 grams /second) coming from MAF with a TPS sensor at throttle indicating less than half throttle load and less than 2200 rpms.In this condition ECM sets itself to a default value untill ignition is cycled,and a code 33 is set & ceck engine light come on steady.
i think about 2 test to do:
1) May be, as i told, a faulty MAF module (so it's called in 85' tunedport,then in 86 it becomes burn-off relais and MAF power relais,but a different ECM in 86'(165) and different wiring) btw it's very difficult to find one and must be serviced if faulty,you don't find anyone at Ecklers or so...Code 33 trouble chart in 85' FSM requires a lot of cecks with a light bulb to verify grounds that are MAF circuit related,i'll send you a scan but isn't good,find a 85' FSM if you haven't.
2) If your TPS isn't good it comes on with a code 22,but try to ceck as usually .054 volts at TPS with the car in D at 500 rpm,just to be sure your TPS is good ...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
To 85 MAF problems
