Heater doesnt work
Old Oct 30, 2011 | 09:37 PM
87Vetteowner's Avatar
87Vetteowner
Default Heater doesnt work
I have an 87 Coupe. Automatic.
I have the C68 Electronic Climate Control. The unit works and has been rebuilt.
Also, my AC and Defroster works, but there is little to no heat.
What is the best way to go about troubleshooting it ? And possibly fixing it ?
Any links, other articles are fine with me. I want to get headed in the right direction.
Thank you,
Harry C.
Old Oct 30, 2011 | 09:50 PM
oldalaskaman's Avatar
oldalaskaman
make sure the blend door is working
Old Oct 31, 2011 | 12:44 AM
Cliff Harris's Avatar
Cliff Harris
Check the heater control valve between the tubes that go into the firewall on the passenger side. There is a valve there that bypasses the heater core when you turn on the A/C. It is controlled by vacuum. Make sure that valve is switching when you go from A/C to heat. You should be able to see a change in the position of the lever on the side of the valve. Since it's vacuum, the engine has to be running to do this test.
Here's a picture from my '86 shop manual. Note that this picture will give you an idea of where this is located but that is NOT what my car has in it. The valve in my car is attached to the lower tube very close to the firewall. My FSM has several pictures of carburetors, so I think they were just picking something close to put in the manual...
Old Nov 1, 2011 | 08:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The door and the valve are your likely suspects.
You can remove the blower control module from housing and have a look inside, while someone switches from cool to hot. If the door is working, you should see it moving.
Same goes for the valve on heater core line.
Here is all the HVAC info from my 86 FSM.
http://members.shaw.ca/dankai/HVAV'S.pdf
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Old Nov 1, 2011 | 09:10 AM
87Vetteowner
Everything seems to work, but still no heat.
Now, I have read to do a reverse flush of the heater core ..
Which is the inlet and outlet of the heater core ?
Thank you much ..
To Heater doesnt work
