Need help; not getting spark
Old Jun 11, 2014 | 02:14 AM
Cliff Harris's Avatar
Cliff Harris
Sounds like your battery is dead. Did you measure the voltage at the battery with the ignition on?
Another possibility is that one of the battery cables is bad. I had a battery leak at the battery terminal and eat up the wire inside the cable. There was no visible evidence of a problem.
Old Jun 12, 2014 | 01:01 PM
48vette's Avatar
48vette
8th Gear
Originally Posted by 48vette
I need to make a correction..The voltage with the ignition turned on but NOT cranking is 9.5 volts. This is at both the battery side and tach side of the coil.
Thanks in advance any further recommendations.
Bob
The voltage at the battery posts with the ignition turned on stays at 12 volts and the voltage at the distributor is still 9.5 volts at the distributor and tach side
Old Jun 12, 2014 | 03:30 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Should read close to the battery voltage.
1) Is 9.5 volts with the Pink wire at the distributor unplugged or plugged into the cap?
2) If 9.5 volts when plugged into the cap, unplug the White Tach wire does it change the voltage?
3) If it's 9.5 with it unplugged something is wrong with the wiring
or the ignition switch contacts.
Old Jun 13, 2014 | 01:40 PM
48vette's Avatar
48vette
8th Gear
Just checked voltages again and they are as follows:
Battery with or without ignition switch on = 12.2 volts
Pink wire plugged into Dist coil = 11.9v Ignition on
White wire plugged into Dist coil = 11.9v Ignition on
Pink wire plugged in and white wire unplugged = 11.7v at both ignition and tach contacts of the coil - Ignition on
Both Pink wire and White wire unplugged = 11.9v at pink wire and zero volts at white wire - ignition on
Old Jun 13, 2014 | 07:46 PM
Hooked on Vettes
Voltages look normal.
Are you sure you are plugging the Pink wire to the Batt. plug in the cap
and the White terminal in the Tach terminal?
Disconnect the EST bypass wire and see if you get spark.
This is the Brown/Tan wire by the brake booster you disconnect when you
time the engine.
If no spark, remove the distributor cap and verify the rotor is actually turning
when you crank the engine.
If still no spark, on the 4 wire distributor connector plug, use an ohm meter and verify while the plug is still connected the Black/Red wire has continuity with the negative battey terminal. If you can't back probe the connector use a sewing need and poke through the Black/Red wire insulation if you can.
Old Jun 14, 2014 | 02:20 AM
Cliff Harris
Are you sure you are plugging the Pink wire to the Batt. plug in the cap and the White terminal in the Tach terminal?
The connectors are keyed, so you can't get them switched (unless you use a lot of muscle to force them in).
