Failed Brake Balancer Test :/
Old Nov 8, 2011 | 09:01 AM
armybyrd's Avatar
armybyrd
Default Failed Brake Balancer Test :/
Im here in Germany and my '88(L98/4+3) failed inspection when the put her on the brake balancer. Now my parking brake works fine as it does hold the car until around 1500rpm. THe numbers I got from the balance are 280 for both fronts and ?30(cant read what the first number is-maybe a 1) for both rears. They listed those numbers under "footbrake" on the inspection paper and under "handbrake" they wrote No Power and 50 for LH and 50 for RH. Any one have any idea what this is indicative of as far as what specifically could be the problem with my parking brake?
Old Nov 8, 2011 | 10:26 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
We don't have those tests here in the states as far as I know.
You'll have to ask or look up the law for what the minumum values are.
May just need a more agressive pad and a brake fluid flush.
Good Luck!
Old Nov 8, 2011 | 10:47 AM
engle1147's Avatar
engle1147
To me that sounds like they are messing with you. Next time you go back for a re test slide (or leave it out in the open inside the car) the guy some cash within your paper work before you get started - I bet you sail right through. It may sound incorrect but it is pretty much totally legal to do a maximum of a $50 (USD or the equivalent there of) "grease payment"...some personel in various countries expect it.
Old Nov 9, 2011 | 01:20 AM
armybyrd's Avatar
armybyrd
Hmm how serious are you about this? At this point Id do that gladly just to get everything taken care of. Im pretty sure the parking isnt supposed to hold the car in place much past 1500 rpm anyways. Also cant find anyone that sells replacement parking brake cables so not really sure what to replace although C5 brake upgrade for the fronts and new rotors and pads all the way around was on my list to do this winter anyways.
Old Nov 9, 2011 | 09:17 AM
1991Z07's Avatar
1991Z07
Cleaning and lubricating the emergency brake cables and components will go a long way to making the system work better.
On my '91, it will literally stall the engine if you release the clutch with the parking brakes applied...moving nowhere.
Old Nov 9, 2011 | 12:19 PM
c4cruiser's Avatar
c4cruiser
Good Luck!
From what I have read, vehicles that belong to US servicemen and are shipped to Europe have to EU license plate and they have to conform to that country's laws. In the past, the military issued their own plates with a "USA" designation on them. I remember we had to pass a safety inspection but it wasn't much more than the basic stuff.
Have you done a fluid flush? Are there any issues with the ABS system? If the line pressures are significantly different between front and rear, it may indicate some sort of problem with the ABS system.
Also, what condition are the rear flexible brake hoses in? It may be that one or both of the rear rubber hoses may be starting to degrade. But it won't affect parking brake performance.
The parking brake is controlled by cables only and uses the rear calipers to hold the car. Each caliper has an arm the cables attach to. But if the parking brake holds the car up to 1500 RPM, is it the German standard that can't be met??
It could also be that the rear calipers are worn or the pistons are not easily moving in the bores.
Old Nov 9, 2011 | 01:15 PM
TheFinn's Avatar
TheFinn
Mein Herr, es ist möglich das Bestechung Beamten normal in Florida ist aber in Europa - besonders in Deutschland - das wäre ein grosser Fehler.
Old Nov 9, 2011 | 01:24 PM
TheFinn's Avatar
TheFinn
Combination of old cables and somewhat stuck calipers?
Summit and other companies ship parts just about daily to Europe so getting new parts should not be a problem.
Old Nov 9, 2011 | 01:32 PM
engle1147's Avatar
engle1147
Mein Mann, ich war in Deutschland geboren so wissen Sie, dass ich aus meinem Esel nicht spreche - Wissen, dass die ganze Welt in einem "grauen" Gebiet unabhängig von jemandes Position funktioniert, es sein, machen Flordia oder Deutschland - keinen Unterschied. Eine parkende Bremse ist, um nicht "zu parken", um die haltende Macht einer Kupplung oder anderer solcher Dummkeit zu prüfen.
Old Nov 10, 2011 | 03:37 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
IMO the Germans are not about messing around when approving older cars on the Autobahn.
Grease money? waacha talking about? Some lawless city in the states or Mexico?
Old Nov 10, 2011 | 11:38 AM
engle1147's Avatar
engle1147
Some of this may help.
U.S. Federal Motor Vehicle Safety Standard 105 excerpt ( http://edocket.access.gpo.gov/cfr_20...cfr571.105.htm ):
"Parking brakes must hold a vehicle in forward and reverse directions on a 30% grade for five minutes."
I know your not in England but here is some "Roller brake test info/terms that popped up in a search:
http://www.ukmot.com/3-7.asp
I only skimmed this but perhaps you can get them to disqualify this brake testing....some examples are given.
Ramstein: http://www.ramstein.af.mil/library/f...t.asp?id=17109
"4. Brake inspection
Braking effort from any wheel less than 70% of maximum effort recorded from another wheel on the same axle or during road testing, the vehicle deviates excessively from a straight line"
http://www.letsgo-europe.com/Germany...cting_car.html
"In some cases where a car does not pass inspection, but the faults found are not life threatening, you will be able to register your vehicle and receive your plates contingent on you having paid for (and have the receipt for) replacement parts and installation of those parts for your vehicle. It is up to the inspector as to whether this will be acceptable."
Importing a car into Germany FAQs:
http://www.mapsupport.com/thedatabas...prtgvehger.htm
Old Nov 11, 2011 | 08:39 AM
dclafleur's Avatar
dclafleur
It sounds like it might be more of a problem with the balance between front and rear braking as that's what I normally think of when someone talks about balancing brakes. Are you sure their complaint is with the handbrake?
Old Nov 11, 2011 | 12:13 PM
tunedport85inject's Avatar
tunedport85inject
replace your pads,ceck brake cable,have a good lines flushing and bleding...it's a good investiment in your car safety, specially in a cold winter in Germany...
Old Nov 11, 2011 | 01:42 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I would think this is the case by what the OP has said. Basically, you have a big deviation between the left and right sides of the car, or one wheel is not braking properly. What this is going to cause is the car to careen to the weak side, whichever side it may be on.
I would do all the PM that has been mentioned. You may be looking at a partially frozen caliper though.
Old Nov 12, 2011 | 01:49 AM
armybyrd's Avatar
armybyrd
Havent flushed the brake fluid out yet-was planning on doing that when I do my C5 brake swap with new ss lines though I might have to do it now. THe inspection is for Germany.
Old Nov 12, 2011 | 01:50 AM
armybyrd's Avatar
armybyrd
Summit used to be one of the main places I got parts from but they dont ship to APO addresses :/
Old Nov 12, 2011 | 01:53 AM
armybyrd's Avatar
armybyrd
Yes to paint you guys a picture of this whole balancer test-it looks like a dyno kinda. Your drive wheels are parked over these parts that start to spin. They engage the parking brake and then spin the machine and the screen shows some numbers which Im assuming have to do with how much each side is holding and at what speed of the machine it stops holding.
My regular brakes are fine-never had any abs problems either
To Failed Brake Balancer Test :/
Old Nov 12, 2011 | 01:57 AM
armybyrd's Avatar
armybyrd
Alright just to keep you all posted-Ive already got everything needed to do the front C5 upgrade including new rotors and Hawk pads. Also have stainless lines. Just ordered a complete brake cable set. Hopefully my calipers dont need to be replaced.
Old Nov 12, 2011 | 04:53 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In VII Veteran
I have Summit ship to my APO address all the time. If they no longer do, this is a very recent development as my last order was shipped at the end of August!
Old Nov 13, 2011 | 02:04 AM
armybyrd's Avatar
armybyrd
I just checked with Summit and they do ship to APO-its just their auctions on ebay that always say no APO for some reason.
