super ram?
Old Nov 20, 2011 | 11:53 AM
89L98TPI's Avatar
89L98TPI
Default super ram?
Again I have a 89 coupe auto bone stock. Im looking to get the most bang for my Buck. Can I get a super ram setup with 219 cam on my stock bottom or am I better off get tpi system ported with 211 cam. I know ill need a tune but am just lost where to begin or what way to go with this car. Changing the bottom right now isn't in budget or 383 it would be. So what u guys think. Thanks guys
Old Nov 20, 2011 | 01:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
Some may disagree but the Superam and the 211 cam would work good
By the time you buy the aftermarket TPI then port it to breathe youll be in it more $ than a superram.
If you ever go 383 you can port the superram and reuse it.
Old Nov 20, 2011 | 01:29 PM
cumbercr's Avatar
cumbercr
I agree with Ron. I ran the Super Ram with a mild 260AH cam and had good results. Add some headers to get even more out of it. I'm running an unported SR on my 396 and I don't feel any lack of power. So that's an intake that will work when your budget allows a complete rebuild.
Old Nov 20, 2011 | 01:34 PM
383vett's Avatar
383vett
The SuperRam will give you a flat torque curve, great drivablility and will support a good amout of hp for future mods.
Old Nov 20, 2011 | 01:35 PM
89L98TPI's Avatar
89L98TPI
I was planning on getting my stock intake and Plenum ported and set of LTR. Just didn't know if ram was going to hurt the performance of my car. I've been under the assumption that RAM setups in general were for higher rev motors but read Vader86 page and he said it would work. This TPI motor is confusing.
I would also get headers and AFR 195. I was told yesterday 180 would be better for stock bottom but I'd love to 383 down the road. Looking to spend now about 5 grand. Exhaust 1500 I figured another 1500 for heads then I'm lost on intake setup. I love original Tpi look but who
doesn't love the look of super
ram. Thanks again for any advice.
Old Nov 20, 2011 | 01:37 PM
89L98TPI's Avatar
89L98TPI
Thanks guys. My name is Ron as well. Just your average backyard mechanic with friends but huge Corvette enthusiast. Thanks for all your advice
Old Nov 20, 2011 | 06:38 PM
cumbercr's Avatar
cumbercr
The AFR 180's may look better for a stock bottom end. But I found the 195's to work great on a 350 with the Super Ram. The key is that they will also work well with a larger displacement engine. I'm running 195's with the SR on my 396. Vader86 has the identical motor built by the same builder. It's a proven combination.
Old Nov 20, 2011 | 07:15 PM
weaselbeak's Avatar
weaselbeak
If your thinking AFr heads I would pm tpi421vette as he has done several forum members well on here. I bought some AFR 195's from him and then paid extra to have them flat milled and with shipping I would have been in the 1500 range.
Old Nov 20, 2011 | 07:53 PM
383vett's Avatar
383vett
Jim is a good source for afr heads and he builds a mean engine too. Good honest guy who has helped many members. Willie
Old Nov 20, 2011 | 08:22 PM
cumbercr's Avatar
cumbercr
Jim built my motor and sold me the AFR's. Great guy!
Old Nov 20, 2011 | 08:25 PM
vetteoz's Avatar
vetteoz
Originally Posted by 89L98TPI
I've been under the assumption that RAM setups in general were for higher rev motors .
All TPI based ,long runner intakes :
peak lower and have massive bottom end torque
MR , HSR ,SP intakes for top end ( and a "relative" loss of bottom end )
SR is sort of mid way between the two
Compare the power curves here
http://xtremecarzone.com.au/index.php?showtopic=386
Old Nov 20, 2011 | 10:44 PM
Beach Bum's Avatar
Beach Bum
Once upon a time I ran all combinations of the above.... my first build was with the original 350 with Accell runners/base with 211 cam, then Superram with 211 cam and then with 219 cam.
The best for acceleration is easily the Superram and 219 combination. As always, when you move your power up into the rpm range, you will want/need to loosen up your converter a little bit. If you're not going to race, a low cost 2400-2600 rpm 12" converter is just fine, if you're wanting to optimize your et's a little bit more, then a 2800-3000 rpm 10" converter would be my recommendation.
With good cylinder heads, you can easily get the combination into the 11's with a little work. PM me if you want additional information.
To super ram?
