89 with three engine codes.
Old Nov 21, 2011 | 11:38 AM
ODST's Avatar
ODST
Default 89 with three engine codes.
Hello everyone! A couple of weeks ago my check engine light came on so I pulled the codes and came up with three:
Code 13 = oxygen sensor
Code 32 = EGR system
Code 33 = map sensor.
I do not have a FSM, all I have is the hanes book (better than nothing).
On the oxygen sensor, I was going to just replace it and see if that fixes the problem unless there is a way to test the circuit and see if something else is causing the problem. Any tech info on this will be greatly appreciated. I was also wondering if the oxygen sensor would make the other two codes show up, if not does anyone know what I can do to test these as well so I can determine the fix for the problem.
Thank you in advance for your time and your knowledge.
Old Nov 21, 2011 | 12:22 PM
engle1147's Avatar
engle1147
Code #33: for the 1989 would be "Mass Air Flow Sensor High". MAP sensor went into these car in 1990.
Swap the O2 sensor, change out the 2 MAF sensor relays on the firewall behind the battery. Visualy check the electrical connections/wiring for the EGR protion of the smog system.
Clear the store trouble codes (disconnect the battery for a minute or so) start the car and see what codes/issues still need to be addressed.
Old Nov 21, 2011 | 12:27 PM
ODST's Avatar
ODST
Thank you. I will replace the o2 sensor today and the relays.
To 89 with three engine codes.
