Code H63 keeps coming back
Old Nov 23, 2011 | 07:40 PM
frenchsquared's Avatar
frenchsquared
Default Code H63 keeps coming back
I know that is the right o2 sensor circuit being open.
I am guessing that means I need to replace the right o2 sensor?
Is this a typical o2 sensor found somewhere on the right side, in or just after the exhaust manifold?
Old Nov 24, 2011 | 10:15 AM
pcolt94's Avatar
pcolt94
Please post what year car.
Connecting a scanner would verify fuel trim readings to give you a warm feeling before replacing the O2 sensor.
Old Nov 24, 2011 | 11:16 AM
frenchsquared
1994, H63 code is under section 9
I had The dealer and a local shop try to hook a scanner up.
Both told me there were no codes.
Old Nov 24, 2011 | 01:11 PM
2012 coupe's Avatar
2012 coupe
Default H63
I have had a H13 & H63 error since I installed the new motor a year ago. I have changed the O2's twice, had the wiring checked. The FSM says that if it is intermittent, which mine is, then change the ECM. I am going to change the ECM next week and see if that fixes it. Had scanner on system and no errors after clearing the old ones. They (errors), return after a while driving on the freeway. I have a new Tune done and that fixed the errors that had to do with O2's running lean.
I would be interested if anyone has had the same problems and what fixed it.
Old Nov 24, 2011 | 03:26 PM
Kmcoldcars's Avatar
Kmcoldcars
My 1992 has been giving intermittent left bank lean error codes. I replaced the left 02 sensor, which did not help. I also replaced the fuel injectors as they were the original multi techs. The car ran better but I still got the lean codes. I then found a hole in a vacuum line going to the cruise control module. Replacing the vacuum line made the cruise control work but I still had the lean codes, intermittently. I then bought a 10 meg ohm impedance multi meter and tracked the problem down to what appeared to be the ECM.
Removing the connector that had the wires going to the 2 O2 sensors from the ECM, I was able to measure 1.1 volts going to the right sensor but only 13 mv going to the left sensor from the ECM, with the key on but the engine not running.
I sent the ECM out to be rebuilt. Yesterday I put it in the car but have not had a chance to take it out yet. Hopefully tomorrow I can get it out. I will let you know how it goes.
Old Nov 24, 2011 | 04:31 PM
pcolt94's Avatar
pcolt94
Module 9 is the brake computer. Only module 4 would give you a O2 error code.
Not home this week so I cant look up the code for module 9.
Maybe someone will chime in with the info.
Old Nov 25, 2011 | 02:40 PM
Kmcoldcars's Avatar
Kmcoldcars
Today I got my 1992 out for a couple of nice drives after replacing the ECM. I did not get any error codes. Hopefully my codes for left 02 sensor lean are now gone.
Old Nov 25, 2011 | 10:47 PM
pcolt94's Avatar
pcolt94
That is just great. The ECM can definitely cause the problem.
Just wondering are you pulling the codes with the on board diagnostics since you said the dealer could not find any with a scanner?
Old Nov 26, 2011 | 11:41 AM
frenchsquared
I used the on board diagnostics with a jumper.
I figured out that codes were different for each section.
I need my FSM to get here.
H63 in section 9 for a 94 is "Valve solenoid relay fault"
I checked both relays, they seem to be working fine.
So without more guidance or a FSM I think I am out of luck.
Old Nov 26, 2011 | 08:48 PM
pcolt94's Avatar
pcolt94
You can clear the codes for module 1 & 4 by disconnecting the battery. It doesn't work like that for module 9. They have to be cleared using the on board diagnostics using module 9.7. I would clear the codes and see if it returns before I did any troubleshooting for the Valve solenoid.
Does the car make the ratcheting noise from the rear at 4 mph. And does it seem like the ABS is working when a wheel locks up. If both answers are yes, then that sounds like things are working.
Do you have a ABS light on?
Old Nov 26, 2011 | 10:11 PM
frenchsquared
Im certain there was a problem.
I cleared the code 3 times, it comes back before even starting the car.
There wasn't any power getting to the modulator.
No, the car was not doing a self check of the abs. It will not do the self
check if there is an error. No, the abs was not working. No the ARS was not working.
I am 100% certain the was a break in the main power wire.
I just haven't taken the time to find the break.
I ran a new wire and everything is working. I will find the brake when it is warmer.
Old Nov 27, 2011 | 12:17 PM
pcolt94's Avatar
pcolt94
Right now the best place I can say to start is to check the brake hydraulics fuse. It is 40 A fuse in a fuse box under the hood fuse #8. There are 2 fuse boxes near the battery, you will have to finger out which one it is, I'm not sure.
If that is good then check the connector for the ABS unit behind the driver's seat in the compartment. Inspect, clean, re-seat, etc.
Old Nov 27, 2011 | 08:40 PM
frenchsquared
I'm not going to worry about it.
The fuse is fine. The wire is broke some where.
I just ran a new wire.
Old Nov 14, 2014 | 04:06 PM
ARTIC TRUCK's Avatar
ARTIC TRUCK
Hi
Did your find the fault (H63)?
I have the same fault
I changed the ABS control unit
but that is not the fault
What I can do?
thanks
To Code H63 keeps coming back
