CCM codes
Old Oct 30, 2014 | 11:23 AM
okmac's Avatar
okmac
Default CCM codes
I have a 1991 Corvette, when i check the codes , by shorting out pins G and A I come up with the following codes for module 1. 31,32,33,34,35,36,37, and 38 . I can find nothing wrong with any on the instruments. Could someone tell me what i should be looking for. I have the manual so know what these codes are.
I have had the car stall a couple of times lately, could these codes indicate what the problem is ? As i understand it module 1 only has to do the the instruments.
Mac
Old Oct 31, 2014 | 12:27 AM
Cliff Harris's Avatar
Cliff Harris
According to the info I have, you should be shorting pins A & B to read the codes in a '91:
http://forums.corvetteforum.com/1574918379-post18.html
http://corvettephotographs.com/c4vettes/codes.htm
My experience is that sometimes the ECM goes wacko and stores a bunch of codes that are not really valid. The way to find out is to reset the ECM and see what codes show up. Disconnect the ECM power connector for a second or so:
Not all cars have this connector. If your car does not then you'll have to disconnect the negative battery cable.
Old Oct 31, 2014 | 11:40 AM
okmac's Avatar
okmac
I agree with the A and B pin if you want to check codes on the ECM, however if you want to check codes on the CCM you need to short out A and G , when you do this you will get error codes from both systems. This only applys to 90-93.
I think I will just clear the codes and drive it and see if they show up again.
Mac
Old Nov 13, 2014 | 02:58 PM
ARTIC TRUCK's Avatar
ARTIC TRUCK
Mac
hi
How do I can erase the codes of EBTCM?
Where to I can buy the machine to scan the error codes CCM, ECM and EBTCM?
thanks
best regards
Old Nov 13, 2014 | 03:22 PM
okmac's Avatar
okmac
Originally Posted by ARTIC TRUCK
hi
thanks
best regards
What year Corvette are you talking about?
You can purchase a scanner in almost any auto parts store , you just need to know what system you will be checking. OBD1 or OBD2
Mac
Old Nov 13, 2014 | 03:48 PM
ARTIC TRUCK
Mac
93 corvette
Old Nov 13, 2014 | 04:28 PM
okmac's Avatar
okmac
93 corvette
This site should answer your questions. On a 93 you do not need to buy a scanner as you have a built in one.
http://tech.corvettecentral.com/2011...trouble-codes/
Mac
Old Nov 14, 2014 | 11:39 AM
ARTIC TRUCK
Mac
hi
I tried deleting the ABS codes and reappears H63 code.
otherwise, the ABS control unit is changed (new)
I need help, please-
thanks
Old Nov 14, 2014 | 02:38 PM
okmac's Avatar
okmac
hi
thanks
Not very familiar with abs codes. Here is a guy with the same problem. Maybe that will help. Read the last part of the thread.
https://www.corvetteforum.com/forums...ming-back.html
Mac
Old Nov 14, 2014 | 04:09 PM
ARTIC TRUCK
Mac
thanks Mac
To CCM codes
