Back On The Ground...
This is a week before I took it part:
I removed the interior, engine, and front suspension to begin my project. I work on it as money allows (which is why it is taking so long).
Here are the front upper control arms I made:
Here is my custom way of mounting the front spring to get it low enough with all the weight out. I used the Banski spring mount kit and drilled holes in the spring and control arm:
Here it is today on the ground finally! (The Black Rose C4 is my dad's '92 all stock street car)
This is how low I can get the car with no engine, trans, or interior! I have room to raise it up more.
Not too much to show, I still have to finish the engine and paint it, and put a cage in, but this was a big step today and I wanted to share.
Thats what a "project" is supposed to look like ! ....progress, improvement, upgraded, personalized with a purpose. Still the same basic car, on steriods.
Did you consider the steering geometry when building those A arms? Thats one of the ways GM got the tight precise handling of the C4 was to offset the spindle a few degrees off center of the arm travel/center. I'm sure curious what a little more or a bit less would be like. Moving it rearward or forward...nice looking fab job !
I'm curious...why did you elect to weld one side ( A-arm) and use a bolt in the other? I'd be a little concerned about that welded stud cracking at the plate junction....
thats is impressive.DIY UCA and modified LCA-AWESOME
The donut you speak of is actually made of delrin and is incompressible. The bottom diameter of it is actually almost the width of the spring at the mounting location so it does distribute a lot of load. I thought about putting a large fender washer under it, but I dont think it is needed.
For my race class you have to take points for every modification you do. Each type of modification is worth a different number of points. For instance changing control arms is +6points, and using heim joints instead of rubber bushings is +3 points, etc etc. The more points you acquire the higher up in class you go (from the base class of the vehicle). Every 20 points you get puts you in a new class. Going to a coilover would cost more points than using a different rate leaf (+4 vs +2). The class I am trying to stay in is the fastest class that still uses the points system. The next class up is unlimited points and only controlled by a wt/power ratio. Basically deepest pockets wins that class. And probably the biggest reason I did this, Im poor.
Therefore I make things I cannot afford.
I will be sure to update this when the car hits the track.
I will say I am a bit leary/wary of that hole you now have in the spring...what was wrong with the old slip/pinch stocker style mount?
