Valve stem seal replacement info
Old Dec 21, 2011 | 12:41 PM
  #41
oldalaskaman's Avatar
oldalaskaman
Originally Posted by Joe B.
You install two seals, a positive seal and an umbrella seal on each valve?
yes , not actually needed but when you do things on a percentage you dont want them back for a loose seal
Old Dec 23, 2011 | 12:58 PM
  #42
tim1's Avatar
tim1
Well yesterday I got the bad news from my motor. It seems we did not get the valves are not adjusted properly. So I janked it apart again and tried it again, got it together a few minuets ago and still not adjusted correctly. I followed the FSM to the letter(or so I believe). So does anyone have suggestions on how to adjust one cylinder at a time? This may take longer but I am frustrated with the vette sitting there and not running. So shot me your ideas on how to do one cylinder at a time and I will start tearing back into the valve adjustments.
Old Dec 23, 2011 | 01:04 PM
  #43
oldalaskaman
its pretty common , first time thru, theres a good tech , article , let me find it and I'll pm it to you. is it running and noisy or not running?
Old Dec 23, 2011 | 01:13 PM
  #44
tim1's Avatar
tim1
I really need all the help I can get Alaska man. I have torn it apart twice now and getting ready to open it up again. I am starting to get very tired of doing this and am almost ready to get it towed to a repair shop. Before I do that though I will give it one more attempt. Thanks for helping me and keeping my head above water.....
Old Dec 23, 2011 | 01:40 PM
  #45
oldalaskaman
patience grasshopper, you have pm, look at this as a learning event, make sure to double check that the plug wires are on the right plugs
Old Dec 23, 2011 | 02:17 PM
  #46
tim1's Avatar
tim1
Showing patience here, top end is already back off. Going to read my pm and ****** the pebble from your hand....LOL
Old Dec 23, 2011 | 02:20 PM
  #47
STL94LT1's Avatar
STL94LT1
You can adjust one cylinder at a time if you can find a true compression stroke TDC. Find compression stroke TDC for the #1 cylinder, adjust both valves. Then turning the crank 90*/1/4 turn follow the firing order 1-8-4-3-6-5-7-2 and adjust the valves on each cylinder.
Just remember if the engine hasn't been ran that the lifters can be bled down and it is easy to overadjust. I like to move the pushrod up and down to find 0 lash. Once there is no movement in the pushrod, adjust the valve 1 full turn.
Old Dec 23, 2011 | 02:42 PM
  #48
tim1's Avatar
tim1
Heres is the question for the forum.... After I get #1 to TDC and adjust the 8 valves as the FSM states do I ...... Rotate the crankshaft 360 degress or 180 degress before I adjust the last 8 valves??? Or do I ... roate the crank untill number 1 comes back to TDC before I adjust the last 8 valves as stated in the FSM????
Things that make you hmmmmmmm
and scratch alot......
ROFLMAO
Old Dec 23, 2011 | 03:19 PM
  #49
STL94LT1's Avatar
STL94LT1
Rotate the crankshaft 1 full turn/360*. #1 will again be at TDC, but on the compression stroke.
Old Dec 23, 2011 | 03:23 PM
  #50
tim1's Avatar
tim1
That is what I have done twice so far SLT, and still no compression and backfiring.
Old Dec 23, 2011 | 03:26 PM
  #51
STL94LT1's Avatar
STL94LT1
Sounds like you are not finding 0-lash and overtightning the valves, leaving them open.
Old Dec 23, 2011 | 03:33 PM
  #52
oldalaskaman
you have pm,
Old Dec 25, 2011 | 12:34 AM
  #53
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I have used this method with good results:
http://www.youtube.com/watch?v=NKH13q28t6w
Old Dec 25, 2011 | 01:20 AM
  #54
oldalaskaman
thats the method I pm'd him,
i didnt have that excellent video though, many thanks, respectfully and best wishes, bob
Old Dec 25, 2011 | 04:28 AM
  #55
tim1's Avatar
tim1
Well Alaskaman failed again. I must not be setting it on the compression stroke. I will watch the video and try it again, maybe today.
Merry Christmas
Tim
Old Dec 25, 2011 | 06:06 AM
  #56
blackozvet's Avatar
blackozvet
just for info here is a write up with pictures I did on this subject,
http://forums.corvetteforum.com/c4-t...ron-heads.html
also the umbrella seals are designed to compensate for wear in the valve guides so as they wear the umbrella seals stop the oil from going down the guide and into the combustion chamber.
Old Dec 25, 2011 | 06:32 AM
  #57
tim1's Avatar
tim1
This may have helped a week ago and then we would have started disassembly on compression #1 cylinder. Now the rockers have been removed and reinstalled 3 times and still not on compression #1.
So I keep doing the hit and miss and hoping I get it on compression TDC #1. Attempt #4 starts today.
To Valve stem seal replacement info
Old Dec 25, 2011 | 07:00 AM
  #58
tim1's Avatar
tim1
I am thinking of taking both rockers off number one cyl. and rotating the motor over by hand while watching the push rods moving. To try and get it to compression TDC. The question is ---- In which postion should both push rods be when #1 cyl is TDC compression? I am hoping that this will work and get the motor on the correct stroke. HELPPPPPPPPPPPP, thanks everyone for all comments.
Old Dec 25, 2011 | 09:32 AM
  #59
STL94LT1's Avatar
STL94LT1
^^^ Both valves will be closed on the compression stroke.
Old Dec 25, 2011 | 09:51 AM
  #60
tim1's Avatar
tim1
I understand both will be closed on compression stroke. All my rockers were removed and new stems put on, now we cannot figure out how to ensure we are on compression stroke. I think we put them back together and were not on compression #1. So how can I tell when it is at TDC compression #1 with the valves were not adjusted on the compression stroke??
