Mirror switch
Old Dec 4, 2011 | 03:28 PM
kitttransam's Avatar
kitttransam
Default Mirror switch
Has anybody tried taking apart the power mirror adjustment switch to fix? Mine won't move the mirrors downward and was hoping there's a way to take it apart and fix. I'm on a tight budget and can't afford to buy new parts. It's on an 89 vette.
Old Dec 5, 2011 | 07:14 PM
SunCr's Avatar
SunCr
Beats me, but the switch is long out of production so if you have to replace it, I can't imagine a boneyard charging more than a Buck or two for a used one.
Old Dec 6, 2011 | 12:52 PM
kitttransam
Yeah that's the only bad thing about the area I live. Not to many yards have corvettes.
Old Dec 6, 2011 | 03:31 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If you're talking about the mirror selector switch, yes I pulled and fixed mine several years ago. It's a VERY simple switch...simple design and easy to fix.
The toggle control was a bigger PITA since it had dropped thru. You have to pull the console to get at the mount. Took me several yrs before I ended up with it far enough apart to retighten the allen screw.
Everything is perfect now. Never had to buy a new part. Same with other switches (like hatch release). They can usually be repaired if you have a bit of ingenuity and patience.
Old Dec 6, 2011 | 03:34 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by SunCr
the switch is long out of production...
Seems like I saw a reproduction of the selector switch during the last couple of years....
Old Dec 6, 2011 | 03:36 PM
kitttransam
Yeah I need the toggle fixed. Seems to me that I would have to get the back side of the switch unglued to get inside the switch.
Old Dec 6, 2011 | 06:51 PM
asjwalsh's Avatar
asjwalsh
I had the same symptom on my 94. Passenger side mirror stopped moving up and down. There is a thread here somewhere, but in a nutshell, I popped the mirror off the mount, got the 'up/down' motor spindle and twisted it to free it. It had seized in place. Not the switch at all. Been working for 6 months now. Hopefully that will be your problem and will save you some cash and time. 10 minute job.
Old Dec 6, 2011 | 07:38 PM
SunCr's Avatar
SunCr
Selector Switch - Left/Right - is/was still available. The Toggle buried in the Console - Up/Down;In/Out - is out of Production. I don't know of anyway to service either without removing the Console Cover though that isn't that difficult.
Old Dec 6, 2011 | 10:49 PM
kitttransam
I don't think it's the mirrors both are doing the same thing.
Old Dec 8, 2011 | 03:34 PM
GREGGPENN's Avatar
GREGGPENN
You have to pull the console. Remove the A/C bezel. Go into the bottom of the center console to detach the rear of the center console. Somewhat hidden "secret" panel hides the screws. The rest is fairly straight forward.
The toggle is held in with an allen screw that must be accessed after pulling up the center transmission bezel.
Old Dec 8, 2011 | 09:20 PM
ctrain22's Avatar
ctrain22
If the switch is still in the console, try spraying some CRC electrical cleaner in to the switch. It worked for me. Mine wouldn't go up or down, but would go sideways. I installed new seat tracks and the tilts didn't work. I heard from someone hear on the forum about this electrical cleaner, tried it, and they all worked. So...I tried it on the mirror toggle also, and now they work. Worth a shot.
To Mirror switch
