fuel injector problem
Old Dec 5, 2011 | 12:15 PM
sourn's Avatar
sourn
Cruising
Default fuel injector problem
My fuel injector went bad while on this trip. Ive already got one ordered but im alittle worried because the rubber seal on the wiring broke in half. The wires themselves are good still, but is this gonna cause fuel to still shoot out from there ( which is whats doing now)
Old Dec 5, 2011 | 12:34 PM
engle1147's Avatar
engle1147
Help us out - include the year of your car in your post.
Unless you have a 9th cold start fuel injector complication the harness side of the fuel injector wiring should have no affect on the injectors ability to hold/leak fuel. From what your describing you upper "o" ring seal for the fuel rail is leaking and the fuel is dripping onto the harness's connector. If this is the case then the new fuel injector(s) with new "O" rings will resolve your leaky situation.
Old Dec 5, 2011 | 12:37 PM
sourn's Avatar
sourn
Cruising
Its 1992 corvette
Old Dec 5, 2011 | 12:44 PM
weaselbeak's Avatar
weaselbeak
You can order a new set of o-rings from FIC that'll fix you up. If one injector went bad and they are all stock I would consider buying a set since you have to take one out anyway. Might as well do them all and have a matched set that you don't have to worry about.
Old Dec 5, 2011 | 01:13 PM
j-wireman's Avatar
j-wireman
Absolutely.
Plus, it's cheaper to buy a whole set than replacing them one at a time. Do you really want to do this job 8 times? I don't think so.
Jon at Fuel Injection Connection is the best.
Old Dec 5, 2011 | 02:12 PM
leesvet's Avatar
leesvet
Why DO people buy ONE injector when you have to go thru so much work and end up with ALL 8 out anyway?
To the OP....if you are trying to describe the rubber seal on the injector electrical plug, that should be repaired or siliconed to prevent shorting or elec grounding. When a inj plug/harness grounds or shorts that is what causes the inj to stick open and dump fuel in as fast as it can flow thru the nozzel.
Inj bodys DO short out internally and IF one did so and caused a problem, thats a pretty big clue that there are 7 others waiting to do the same thing. Why pay to do that 1 at a time? For $200 you get 8 matched, tested & warranteed current design fuel injectors with all the o-rings and gaskets. Your shop is not going to beat that deal. YOU buy the inj set and pay them to do the dirty part if you don;t want to do the repair DIY style. Call Jon @ FIC to get the details on the set.
BTW you can purchase new electrical plugs to fit the injectors at most auto parts stores and solder them in the harness.
Old Dec 5, 2011 | 03:00 PM
tunedport85inject's Avatar
tunedport85inject
Nobody is talking about a fire danger here!...it's very dangerous have gasoline leaking outside from an injector over the manifold or over electric connectors...ask you why every manual chapter starts with "disconnect negative battery cable"...
Old Dec 6, 2011 | 11:03 AM
sourn's Avatar
sourn
Cruising
Will I didn't have much of a choice I was out about 6 hours in my trip (16 hour trip), and just for one it cost 148$. And like the guy mentioned above I maybe a little crazy but fuel spraying on an engine is even a no go for me.
But ya now that I finally made it here I am looking at buying a new set of Bosch injectors which is only gonna cost a tad more then the one I had to buy lol.
Thanks for all the help guys.
To fuel injector problem
