mini ram ?
Old May 8, 2002 | 08:30 PM
daddydahlin's Avatar
daddydahlin
Default mini ram ?
I plan on changing the heads and cam in my 86 , so I want some that will breath better that the stock intake . I was thinking of the mini ram but after reading some of the posts on the forum , I'm not sure if I should since I have an auto with 2.59 gears . I don't want to lose low end and not be able to get the thing moving. What do you think I should do go with the mini ram or is there something better for cars that aren't as highly modified
Old May 8, 2002 | 09:02 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: mini ram ? (daddydahlin)
If you want more torque go with a superram, if you want more horses go with the miniram. It's up to you. Both are much better than stock.
Old May 8, 2002 | 09:48 PM
ralph's Avatar
ralph
Default Re: mini ram ? (C4-Wolf)
what Wolf said............
If you like the torque and dont wanna do gears and converter and such..., but want more the the stock tpi can provide.....go superram.
Old May 8, 2002 | 09:50 PM
Wilson6t7's Avatar
Wilson6t7
So Im curious, does the SR give low end grunt like the stock system and then run out of breathing room. I am looking at the same mod and also cant decide.
Old May 8, 2002 | 09:57 PM
daddydahlin
Default Re: mini ram ? (Micky T)
does the super ram need more hood clearance
Old May 9, 2002 | 12:37 AM
vader86's Avatar
vader86
The superram clears the hood fine.
It runs smoothly up until about 6000-6500 rpm, for this reason its best for an automatic IMO. MR for a 6 speed, and either for a 4+3.
If you want to go for an MR on an automatic, youll really REALLY need at least 3.54-3.73 gears and a 2800 stall Torque Converter.
To mini ram ?
