Ignition Wires
Old Dec 17, 2011 | 12:54 PM
dogfish246's Avatar
dogfish246
Default Ignition Wires
Hey guys,
I use my 96 Lt1 as a daily driver and want to do a tune up.
I am getting A/C Delco Professional Platinum Plugs (Part Number: 41-943)...
What are the better wires out there? I heard that since our Vettes are fiberglass the wrong resistance wires can cause electrical interference?
Are there any articles like this:http://www.streetmachineclub.com/Por...ugs-lowres.pdf but for wires?
Thanks guys
Old Dec 17, 2011 | 01:34 PM
Jimbo 89's Avatar
Jimbo 89
The A/C Delco wires work fine for me.
Old Dec 17, 2011 | 02:21 PM
dogfish246's Avatar
dogfish246
Yea, I am doing my research... It seems that A/C delco wires seem like a good bet! I am trying to find the best deal... Any suggestions?
Old Dec 17, 2011 | 03:41 PM
tlong's Avatar
tlong
autopartstomorrow.com
Old Dec 18, 2011 | 10:20 PM
HlhnEast's Avatar
HlhnEast
Originally Posted by dogfish246
Hey guys,
Thanks guys
Glad you found this spark plug comparison, I couldnt remember where it was. It was also the deciding factor on my A/C pro plats as well. As far as your wires, Ive never heard the EI problems but I would get a good set like A/C, Taylor or MSD
Old Dec 18, 2011 | 11:01 PM
mazdaverx7's Avatar
mazdaverx7
i have a set of MSD wires on my 84. they work great with no issues. i am running NGK plugs and i'm happy with them. no running difference over the AC delco plugs other than a smoother idle.
Old Dec 19, 2011 | 12:45 AM
dogfish246's Avatar
dogfish246
Thanks guys!!! I will check everything out after finals!!!
Old Dec 19, 2011 | 07:36 AM
ddahlgren's Avatar
ddahlgren
I do not want to burst any bubbles here but the results are statistically inconclusive. 99.99% of the strain gages are 1% or less in accuracy. meaning with 408 ft lbs 404 and 412 ft lbs are both probable results with 408 ft lbs being measured. Add to that the correction factors and accuracy of those devices and you have to make a dozen pulls and average them at best. It is magazine hype at it's best. BTW nothing secret about the secret plugs Bosch race plugs and I doubt you will find them at Summit or Jegs if you are using that as your encyclopedia...
Old Dec 19, 2011 | 10:58 AM
dogfish246's Avatar
dogfish246
But it is nice to see numbers confirming that they are all around the same!!!
To Ignition Wires
