Programming the PKE for the C4
Old Dec 19, 2011 | 09:21 AM
flalt4's Avatar
flalt4
Default Programming the PKE for the C4
I'm in need of some help in programming the key fob for the PKE. The fob that came with the car works perfectly but unfortunately it has the screw back which is not correct for the 93-96. I recently located two correct fobs for my 96 but can't get either to work. I swapped the battery from the working fob (the original that I got when I bought the car several years ago) and placed it into each of the two new fobs and attempted to program them but can't get either one to work. I have followed the programming steps outlined in the Owner's Manual and have had some feedback on the NCRS Technical Questions Board. I've followed everyone's recommendations without success.
I was wondering if the problem is that the PKE is somehow locked onto the frequency of the original fob. Both of the new fobs have a different FCC ID from the original.
Thanks.
Old Dec 19, 2011 | 12:37 PM
pcolt94's Avatar
pcolt94
Thanks.
No, If programming and all is working correctly, it disguards the old, and programs the new FOBs into the receiver.
I would have to ask several questions.
1- Are the two new FOBs an known factor that they are good and working.
2- Have you put the battery back in the original FOB to see if it is still working or has stoped.
3- Have you check the battery voltage with a DVM, and what is the voltage measured.
4- Does the PKE lamp light at the correct times with the correct indication during programming procedure. And is there an indication that the procedure was complete and correct or failed.
If it is still working with the original FOB, then it sounds like it might never have went into programming mode.
The battery should measure 3.1 volts or at least better than 3.0 volts. Anything less is no good.
Old Dec 19, 2011 | 01:13 PM
markKlein's Avatar
markKlein
"I can't get it to work" isn't much info to diagnose a problem. Pcolt94 is right, unless something is malfunctioning, it should work. Do what he advises, and if that does not work, give us detailed, step by step description of what you do to program the fobs and what happens at each step.
Having said that, what do you mean by the "screw back"? I'm not familiar with this term. Is it possible that you have an aftermarket alarm system installed? Does your "old" fob look identical to the new fobs, as far as size, buttons, placement, etc.? If not you have not been using the factory system.
I just reread your post, if you mean your old fob was just not NCRS correct, never mind this paragraph.
Old Dec 21, 2011 | 09:07 AM
markKlein's Avatar
markKlein
Any updates on this?
Old Dec 22, 2011 | 09:15 AM
flalt4's Avatar
flalt4
Wanted to retry the programming before I gave up on the FOB and go searching for a replacement. Its been a hectic week so this probably won't happen until after Xmas.
Old Dec 22, 2011 | 02:30 PM
markKlein's Avatar
markKlein
Again, need more details. When you try to program where does it fail? Does everything seem to work fine until you bring the fob in range, but the PKE light does not stop flashing and stay on? Then it could be the fob, especially if your original fob will make the light stay on and can be reprogrammed. Or can you not get to the point where the light is flashing? If that is the case, no fob is going to work, probably a fault in the PKE receiver.
Bottom line, you say you have a working fob now. You should be able to reprogram that fob with no problems. If you can't, it's a problem in the car, not the fobs. (Just for fun, check fuses 26,40 and 42).
Old Dec 23, 2011 | 10:32 AM
flalt4's Avatar
flalt4
Everything works until the point when I bring th fob into range. The PKE light just keeps flashing. Thanks for your troubleshooting suggestions. Looks like I may have purchased a defective FOB on Ebay.
Old Dec 23, 2011 | 12:50 PM
pcolt94's Avatar
pcolt94
Understood what your current situation is.
Does it have the same reaction with either of the 2 FOBs that you purchased?
Have you tried to program the current working FOB to see if there is a difference in the lamp reaction to bringing the FOB into range?
Because if you can't re-program the current working FOB, then perhaps the 2 new FOBs that were bought might be OK and the car (PKE receiver) may be the problem.
Have you checked or changed the battery?
Old Dec 24, 2011 | 05:33 AM
flalt4's Avatar
flalt4
Yes the new FOB reacts the same way. The original (unit I have had for 5 years) still works. I have been swapping the battery between the new unit and the new old one. Thanks.
Old Dec 24, 2011 | 10:31 AM
pcolt94's Avatar
pcolt94
Sorry to be a stickler for details and just trying to understand best as I can. But I don’t really 'understand what you mean when you say; "Yes the new FOB reacts the same way".
Same way as what?
I understand the original FOB is opening the car;
I'm just trying to determine if you can program the original FOB again. That would prove out the cars PKE and electronics is working correctly.
Without having know factors and eliminate some of the variables, it is hard to determine what is definitely good or bad.
Have you ever checked the battery with a (DVM) digital volt meter?
Old Dec 24, 2011 | 02:06 PM
Phat98's Avatar
Phat98
If you have the FSM there are DTC codes that will help you troubleshoot your issue - section 9K. I'd try this first, it will tell you if the PKE receiver is working, if the fobs are being seen, etc. Also as Mark stated, check the fuses if you haven't already.
You could check your antenna connections for the PKE, there's one in the driver's door and one in the right rear of the hatch area. I had a similar problem on my '94 - fob wouldn't work approaching the drivers' side but would from the back - found a broken antenna lead in the door from a botched window repair.
To Programming the PKE for the C4
