Adjustable shocks
Old Dec 30, 2011 | 07:57 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Adjustable shocks
Looking for some recommendations for adjustable shocks. Need them to be stiffer for autoxing. Don't want to go to coilovers.
Old Dec 30, 2011 | 09:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I have Koni yellows and I think they're great for the price. Biggest down side is having to drop the top of the rear to adjust.
Old Dec 30, 2011 | 09:36 PM
96GS#007's Avatar
96GS#007
I run these as well.
Old Dec 30, 2011 | 09:41 PM
dolbnyc's Avatar
dolbnyc
QA1's, I think they are easier to adjust
Old Dec 30, 2011 | 09:46 PM
gerardvg's Avatar
gerardvg
I think from your avatar you have a 90s model ?
there are some adjustable shocks on ebay see the link...
http://www.ebay.com.au/itm/Adjustabl...item2eba55eeb5
These are for the early c4s but you should be able to find them for the later years online.
Just in case here is the ebay numbers
Item number: 200694689461
Corvette central has some coil overs ....
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
i know you said no to them but you will want to adjust ride height for the track and these double adjustable ones will be fantastic, i have coil overs on my vette they are unbelievable
Old Dec 31, 2011 | 01:00 AM
383vett's Avatar
383vett
Kim, I've got a clean set of Koni's that you can have for cheap if you want. Willie
Old Dec 31, 2011 | 06:53 PM
93Rubie's Avatar
93Rubie
I take it you do not have FX3? I too have heard good things about the two way adjustable shocks from Koni. I'd give them a try.
I take it you intend to stay in B Stock?
Old Jan 2, 2012 | 01:40 AM
blackozvet's Avatar
blackozvet
I have the shockers in the link provided by gerard from ebay, and they were a big improvement over the KYB's I took off, easy to adjust using an allen key,
the only thing wrong with them was cardboard stuck to the paint, i re painted mine red,
they are actually made by a well known motorcycle shock company but I cant remember the name of them, maybe someone else knows ?
But very good value for the price !
Old Jan 11, 2012 | 04:02 AM
Shock96's Avatar
Shock96
Ohlins.
Old Jan 12, 2012 | 10:51 PM
Marv02's Avatar
Marv02
I have Koni reds also I like them I picked them up used from anounther member for a good deal.
Old Jan 12, 2012 | 11:42 PM
motodog's Avatar
motodog
Originally Posted by Shock96
Ohlins.
i dont think so. they look like works performance shocks. so so for vintage mx bikes and quads. i dont know how they work on cars. i would go with penske
Old Jan 13, 2012 | 01:13 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If your a serious auto-xer then drop your money on a set of QA1's.
A solid shock with external adjustment is absolutely necessary for track side tuning.
Otherwise its Koni's. Everything else will disappoint you on the track.
Old Jan 13, 2012 | 02:53 AM
Shock96's Avatar
Shock96
Touche'
Old Jan 13, 2012 | 02:58 PM
Bad Karma's Avatar
Bad Karma
Good read on shocks I came across in another thread:
http://farnorthracing.com/autocross_secrets18.html
Old Jan 13, 2012 | 03:27 PM
ekess744's Avatar
ekess744
an interesting read
Old Jan 14, 2012 | 01:03 AM
JrRifleCoach
Originally Posted by ekess744
an interesting read
No. Its great! Sad that most here will not take the time to read.
Shocks, tires, springs, and bars are the last place to skimp if you want a car that runs on rails. HP is great if you can control it.
This writer builds custom shocks that most here would never invest in for the street. But if your serious (Auto-X'r/Roadracer/Mountain roads) this is the kind of guy you need to tune your suspension.
Old Jan 14, 2012 | 04:32 PM
racebum's Avatar
racebum
great link, has been up for many years with very solid advice. the only two cars i have personally tested the koni sports on are the late suspension c4 and 94-01 integra.
the c4 can handle 750-800lb/in tops with the koni sport in front and the rears i never ran out of rebound with since a 500lb rear spring works pretty well with a 750 front
not that anyone might care but if you ever find yourself in an integra to autocross the koni sports for that car are good to about 600lb in the front and 500lb max in the rear....which is kind of crazy since that car is usually setup with more rear spring so it will rotate between the cones
of course everyone's opinion of what's good varies, my rule of thumb is if the shock starts feeling floaty on corner exit you have too much spring
To Adjustable shocks
Old Mar 28, 2012 | 09:47 PM
paulmeisterpk's Avatar
paulmeisterpk
Bought a set of these. I'll have to let you guys know what I think of them during auto-x season.
Old Mar 28, 2012 | 09:54 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
QA1 double adjusters. These shocks allow you to dial in any compression and rebound set up/combination.
You can have the cruise set up, the twisty set up and the autoX set up. Keep a memo pad in the Vette and the rest is fun.
Old Mar 28, 2012 | 11:24 PM
mrc24x's Avatar
mrc24x
You can order these without coil overs:
They might be ok.....
http://www.proracestore.com/index.ph...oducts_id=9783
