tpi performance
Jan 11, 2012 | 10:29 AM
tpi performance
Whats the most h.p you think you could get out of a factory tpi set up. ported or not. large tube runners or not. larger trottle body or not. an no super charger or turbo.
Jan 11, 2012 | 10:37 AM
C4 of Year Winner (appearance mods) 2019
Low 300's to the rear wheels with large tube stuff, cam, and heads.
Possibly more if you're radical enough with porting (e.g., siamesing the base/lower runner walls).
Jan 11, 2012 | 11:07 AM
Quote:
Originally Posted by
GREGGPENN
Mine was 326 HP, 399 lb/ft to rear wheels before the siamese porting...
355 cu/in, CNC ported 118 heads, 1.6 RR, Accel base and TPIS big tube runners.
Once we get the new Bosch3 injectors tuned, I'll be taking it back to see what I gained from that little exercise.
http://temp.corvetteforum.net/c4/joe90/index.shtml
Jan 14, 2012 | 06:11 PM
-Stock heads & cam
-1.6 RR
-ported&siamesed plenum
-siamesed stock runners
-Hedman LT headers
-dual 2.5" exhaust
-stock L-98 mufflers
308 hp @ 4650 rpm (at flywheel)
547 Nm @ 3 450 rpm (at flywheel)
With cam, ported heads and large tube runners a bit more... haven't got the numbers yet.
c4 ,
corvette ,
large ,
parts ,
performance ,
runners ,
tpi ,
tpiperformancecom ,
tube ,
updates ,
upgrades
