igmition start problem
Old Jan 15, 2012 | 01:48 PM
hitmanpty's Avatar
hitmanpty
Ttt
Old Jan 15, 2012 | 02:19 PM
oldalaskaman's Avatar
oldalaskaman
gee, if you saw it on u tube , its gotta be gospel truth, good luck
Old Jan 15, 2012 | 02:34 PM
3D87C4's Avatar
3D87C4
Hi Romulo,
To get a voltage drop current must be flowing. I haven't looked at the schematics so am not quite sure where you are probing. I think there are two possibilities:
There is enough current flowing that the battery voltage itself drops. Some drop is normal since batteries have an internal resistance. The starter motor is a high current load so some voltage drop while starting (or trying to start) will occur.
or
There is a voltage drop due to resistance in the wiring and other circuit components between the battery and the point you are probing. Some drop will occur, I'm not sure how much is normal.
I think you are looking at the circuit that goes from the ignition switch to the starter solenoid, right? The solenoid has two jobs: 1) shove the starter gear into the flywheel gear and 2) close the switch that allows current to flow through the starter motor itself. If the solenoid is engaging but the starter motor isn't then the problem is likely in the starter motor circuit---i.e. the switch the solenoid should be closing, the related wiring and the starter.
Old Jan 15, 2012 | 02:35 PM
hitmanpty's Avatar
hitmanpty
Here is the link for youtube video iam talking about. Look preaty convincent for me. Dont you tell mehttp://m.youtube.com/index?desktop_u...?v=dGem9YsjCRQ
Old Jan 15, 2012 | 02:43 PM
3D87C4's Avatar
3D87C4
Did you replace the starter after your hammer test?
Does the solenoid engage?
Please post up the schematic & maybe indicate where you are probing (cause I'm too lazy to go looking, sorry).
I'm gonna go waste some time on CFOT then do some chores but will check in later.
Old Jan 15, 2012 | 03:15 PM
hitmanpty's Avatar
hitmanpty
You can see wher the pencil show. Where did i do the bypass? Sorry for the bad pic [IMG][/IMG]
Old Jan 15, 2012 | 03:28 PM
3D87C4's Avatar
3D87C4
Ahhhh...it's upside down...my brain hurts!!!
Kidding asside, thanks.
As I recall you did the bypass by bridging the contacts with a piece of metal. There's a good chance this connection is loose, or has burned a bit in use, and is the cause of the voltage drop. I suggest you re-do the bypass using wire with soldered or good twisted connections.
Old Jan 15, 2012 | 03:41 PM
3D87C4's Avatar
3D87C4
Oh, check this first:
Check the voltage on both sides of the bypass as indicated below:
If the voltage is the same then your bypass is probably ok.
Have you checked the voltage at the battery itself when you try starting?
Old Jan 15, 2012 | 03:57 PM
hitmanpty's Avatar
hitmanpty
I remove the metal because i think that was the problema
Old Jan 15, 2012 | 03:58 PM
3D87C4's Avatar
3D87C4
Sorry to belabor this point, but...
If the solenoid is engaging then you need to think about this part of the schematic:
I added arrows to the starter motor and the switch the solenoid has to close to provide current to the motor.
Check out table 1 and 2 below:
Old Jan 15, 2012 | 04:06 PM
3D87C4's Avatar
3D87C4
If
  1. the solenoid isn't engaging
  2. the voltage at the battery isn't changing
  3. and, the voltage at the relay (your pencil location) is dropping
then the voltage drop is occuring in the ignition switch or wiring between the battery and relay.
Old Jan 15, 2012 | 04:09 PM
hitmanpty's Avatar
hitmanpty
I will try to be very crear. Starter motor check out ok on the shop 2 times las time the check wa las monday after the hammer . So the Starter and solenoid aré ok
About voltage . When i check the yellow wire with out the green and white wire the voltage is ok. But if i conect this 2 wire together the voltage drop below 12v
i check in the same placer i do the join see the pictures above
Old Jan 15, 2012 | 04:22 PM
  #33
hitmanpty's Avatar
hitmanpty
If
The voltage in battery drop lite 2 point But don remember eexactely
here i go again if i disconect the yellow wire comino from ignition switch the test will do ok only When i conect to green wire the voltage drop.
So how can the ignition switch be bad
Old Jan 15, 2012 | 04:53 PM
  #34
oldalaskaman
jump from the small post on the starter to the big post
  #35
hitmanpty's Avatar
hitmanpty
No click from the solenoid
Old Jan 15, 2012 | 04:54 PM
  #36
hitmanpty's Avatar
hitmanpty
The starter motor work ok when do that
Old Jan 15, 2012 | 04:57 PM
  #37
hitmanpty's Avatar
hitmanpty
Originally Posted by hitmanpty
Here are some pics i just took like 20 minutes ago[IMG][/IMG]this is testing the yellow wire coming from ignition switch read 12.5 v
Yellow wire alone give me 12.5v? Yellow wire coming from ignition switch
To igmition start problem
Old Jan 15, 2012 | 05:00 PM
  #38
hitmanpty's Avatar
hitmanpty
This a yellow wire now conected to the green and white wire. After connectin the reading show now 11.6 v.[IMG][/IMG]
When i connect yellow wire with green .then i get 11.6v
Test made in the same place. Before the gear selection switch
No click from solenoid
Old Jan 15, 2012 | 05:31 PM
  #39
hitmanpty's Avatar
hitmanpty
Ttt
Old Jan 15, 2012 | 05:40 PM
  #40
rodj's Avatar
rodj
When i connect this 2 wire is when the voltage drop.
Dont know why i get a drop. In voltage.
Basic Elec theory
V= I/R
Where I is current and R is resistance
Measure the circuit resistance between the starter terminal and green/white wire under dash
