Throttle body size vs A/F
St. Jude '10
Can anyone tell me how the A/F mixture will be affected going from a 48mm to a 58mm or vise versa?
Going from a 58 back to a 48, will it make the A/F richer, leaner or no difference?
The ECM will determine the A/F ratio, so I don't think the 58mm TB will be a difference. And the stock 48mm TB will flow more than enough air for not only a stock motor, but also for modded motors.
The stock TB can be increased in size to a 52mm with some machining. A 58mm is really overkill and you most likely won't see any real improvement unless there is something in the stockk unit that requires replacing it.
St. Jude '10
Thanks for the help
You can correct for this by changing the tables that control transient fueling. IE accelleration enrichment.
I removed my 58mm and found the car to be much more driveable and responsive on two different LT1's.
St. Jude '10
Sorry I forgot to mention that one of the issues I'm having is split BLMs. The idle air inlets on many aftermarket TB's need to be modified to eliminate split BLMs.
