87 ECM prom code
Old Jan 17, 2012 | 04:07 PM
quinten's Avatar
quinten
Default 87 ECM prom code
Does anyone know the 4 digit code on the ECM in an 87 vette? Mine has auto trans and highway 2.54:1 rear end. Any help appreciated
Old Jan 17, 2012 | 04:17 PM
oldalaskaman's Avatar
oldalaskaman
http://www.google.com/url?sa=t&rct=j...Nez6tG9U6GtyYw
Old Jan 17, 2012 | 04:24 PM
quinten's Avatar
quinten
I am looking for the broadcast code from what info I can find its 4 letters that denote engine and trans and gearing. Thanks
Old Jan 17, 2012 | 04:40 PM
oldalaskaman
you could do the same search that I did
Old Jan 17, 2012 | 04:55 PM
quinten's Avatar
quinten
I have tried searching and havnt found anything helpful yet was hoping someone knew off hand or had and easy quick ref.
Old Jan 17, 2012 | 09:43 PM
-js-'s Avatar
-js-
Searched:
GM P4 ECM Cross reference
16198259
Schematic
Application: 1986 2.0 L4 TBI “P” LQ5 w/ MT
1986-89 5.0 V8 TPI “F” LB9
1986-89 5.7 V8 TPI “8” L98
1987-91 truck 2.5 L4 TBI “E” LN8
1991 truck 2.5 L4 TBI “A” L38
MEMCAL IDs: “P”: CRY, CRZ, …
“F”: AUM, ACXT, AKFM, AKFR, …
“8”: BUA, AANK, AANL, APYP, APYU, AUJM, …
“E”: ADHF, AMJW, ASWY, AXAA, …
“A”: AUXH, …
EPROM type: 27C128
Old Jan 17, 2012 | 10:24 PM
quinten's Avatar
quinten
From what I found online it looks like abtk is the 87 auto code unless I am missing something I don't see that here. My car has rpo gm1 so it's the 2.59:1 rear and md8 for trans.
Old Jan 17, 2012 | 10:53 PM
oldalaskaman
http://forums.corvetteforum.com/c4-s...d-of-prom.html
check this thread , seems to have it, actually a midyear 86, released in 87, this thread is from 2006 BTW
Old Jan 17, 2012 | 10:56 PM
quinten's Avatar
quinten
I saw that one already but it references the 2.73:1 ratio rpo gu2. Saw somewhere else that Arar is for the 2.59:1 auto but just trying to verify. Thanks for all the help
Old Jan 18, 2012 | 01:28 AM
rodj's Avatar
rodj
ARAR is for 89 Vette w/ 2.59.
Would work in yours but you would have to disconnect the cold start injector as '89+ TPI
added extra cold start fuel through the injectors;
not the standalone CSI used on earlier TPI cars
Not all proms are documented online.
You will note there are 15 different ones for the Vette w/man trans in 87 alone
http://www.chevythunder.com/prom_bcc_1987.htm
Every time GM made any adjustment to a tune they issued a new BCC
Old Jan 18, 2012 | 08:10 AM
quinten's Avatar
quinten
Thanks for the chart! So correct me if I am wrong... As long as I use a code in my car that matches trans and gear I should be fine if all gm did was change the code due to an update. In this case abtd would work.... Thanks again!
To 87 ECM prom code
