I also failed smog test HELP
Old Jan 23, 2012 | 01:11 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by Marv02
The Cat is New the O2 is new everything just about new in the car I am going to try the race gas and the alcohol trick next I hope this works.
If it doesn't, I'd try installing front cats. Magnaflow hi-flows would be my first choice. They sell two options: ceramic or metallic. The later has less restriction -- though either [together] will flow more than your main cat. So, for cost and effectiveness, I might be inclinded to choose the ceramic.
Also, placing cats nearer to the engine makes them perform more effectively.
Old Jan 23, 2012 | 02:33 PM
Caboboy's Avatar
Caboboy
Post 3 addressed the issue. While certainly food for thought, the rest of this is really just aimless discussion.
Old Jan 23, 2012 | 04:15 PM
STL94LT1's Avatar
STL94LT1
This is not a stock engine.
From the OP'd sig.
383 4 bolt main (10.5 to 1) Balanced, Flat top pistons LT-4 Hotcam, Comp Cams ultra pro magnum steel 1.6 RRA, Trick Flow Heads Super 23 (195 runners) 62cc , SPL runners, Hi Flow intake base, 24# FIC Bosch 3 Injectors, Chipped, Melrose full headers, 3 way Main cat, Thrush 2 welded 2 Chamber LT 1 tips.
700r4 Trans built, 2500 Stall Lock up Convertor, 307 rearend.
403 H/P @ 5000
498 TQ @ 3000
If it is lean at idle and rich at 2500 rpms playing with the fuel pressure is not going to help both problems. Look into getting a good tune.
Old Jan 23, 2012 | 06:43 PM
desertmike1's Avatar
desertmike1
From the OP'd sig.
[If it is lean at idle and rich at 2500 rpms playing with the fuel pressure is not going to help both problems. Look into getting a good tune.
He is pushing High CO by .16% at higher RPM he is really close to passing, it will be interisting to see if the "race gas" helps
Old Jan 23, 2012 | 07:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
PM sent
Old Jan 23, 2012 | 08:27 PM
Marv02's Avatar
Marv02
I pulled the Chip and tryed to run the car Now I am getting code 44 it running to lean I try the Alcohol trick and see if it passes.
How much Alcohol should I use.
Old Jan 23, 2012 | 10:21 PM
slickfx3's Avatar
slickfx3
i'm surprised you passed visual with those long tubes
Old Jan 23, 2012 | 10:22 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I run the fuel load down to less than a 1/4 tank then add a pint of the denature stuff.
You might try two. Then after the test, filler up with pump gas.
& Good Luck
Old Jan 24, 2012 | 02:13 PM
Marv02's Avatar
Marv02
Not saying who or where it passed.
The Alcohol didn't Help.
Old Jan 24, 2012 | 02:48 PM
desertmike1
It passed the alcohol did not helped I good for 2 more years untilled next time.
how much did it drop the CO%
Old Jan 24, 2012 | 03:00 PM
JrRifleCoach
Old Jan 24, 2012 | 03:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
So the dentaured alcohol helped or no?
Old Jan 24, 2012 | 04:07 PM
  #33
Marv02's Avatar
Marv02
It was not a steady reading it was lower spometimes and others just as high it was before.
Lets just say it passed.
